Can 10.5 be fit.
Old Apr 30, 2012 | 11:07 PM
pww's Avatar
pww
'05 C55 AMG
Can 10.5 be fit.
Barring opinions on stretch, why I would want to do this, or anything like that:
If running a 255 or a 245 on a 10.5 wheel, has anyone had any experience running rears in this size on our cars?
If you don't have experience with a 10.5", whats the highest offset anyone has run without clearance issues? Want to see how much further inwards from my setup I can go, to avoid going out as much as possible.
Much appreciated,
Pat
Old May 2, 2012 | 09:02 PM
kent426's Avatar
2005 C55, 2006 Ram 2500 MegaCab diesel, sold 2001 Dodge 2500 Cummins, sold 87 190e-16v, sold 97 e420
A 9.5 rim is marginal for a 255, why push a 10.5 rim?
Old May 2, 2012 | 09:15 PM
pww's Avatar
pww
'05 C55 AMG
Just the wheel in question came in a 10.5, that's as much as it matters.
Old May 2, 2012 | 10:36 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
I ran the math w/ wheel/tire set up as the rough base. 18x9.5 ET33 (most peoples run 35-37) + 265/35/18 w/ minor some rolling.
10.5" will require something ET22-25 with a 235/40/18 :x Enough fender rolling + camber, Im pretty sure you can get 245s in there, but 235s will def work :x
PS - i like where your head's at
PS - check out phister's thread and see how his 10" rears fit and use that to create your offsets for 10.5s!
Old May 2, 2012 | 10:58 PM
pww's Avatar
pww
'05 C55 AMG
haha I've been through each of those steps, great minds think alike. Even with Phister's setup, the math I did put me at the same inner clearance as an 18x9.5 et35, and a mm more poke than Phister's setup, which would mean a decent amount of fender work, especially with a 255.. Can't remember what exact offset I came up with, but I decided to opt out for the 9.5, same wheel. Regardless, I'm excited about the new setup I'm gonna have coming soon
