Whine after alternator install
Old Jun 7, 2012 | 12:26 AM
RedBull's Avatar
CLK550
A friend and I replaced the alternator on the C32 today. After everything was reconnected, I started it up and there was a loud whining sound coming from the supercharger. After letting the car idle for several minutes, the whine quieted down significantly, but was still noticeable. The car idles/runs smooth, and drives fine, but there is that whining. Anyone have any ideas what could be causing it?
Old Jun 7, 2012 | 12:29 AM
RedBull's Avatar
CLK550
And I will add that removing the alternator is a major PITA.
Old Jun 7, 2012 | 12:34 AM
Sea55's Avatar
Mercedes C55
To much tension on the serpentine belt?
Old Jun 7, 2012 | 08:50 AM
RedBull's Avatar
CLK550
I'll give that a look today.
Old Jun 7, 2012 | 12:51 PM
Zeppelin's Avatar
C32
Are you sure it is the SC making the noise and not the new alternator? Could be a bad bearing or diode in the alternator.
Old Jun 7, 2012 | 03:06 PM
RedBull's Avatar
CLK550
I'm starting to lean towards the alternator, and the fact that a bit of coolant might have been spilled on it during the install.
