c55 tranny starting in 2nd in all modes....
Old May 30, 2012 | 02:37 AM
arekux's Avatar
2006 C55 AMG
My c55 recently started doing weird things with tranny, in manual mode it starts in 2nd gear, even if it says its in 1st gear, and sport mode does same, it starts in 2nd then downshifts violently to 1st, same happens in sport mode. I understand Comfort mode starts in 2nd, but sport suppose to start in 1st on default right... So far i did tranny service, all oil, gaskets replaced, and tcu was reset, still does this, its annoying, i was reading it could be speed sensors or some valve inside the tranny, it doesn't do this all the time.... i had shop scan my tranny no codes, they said its working as intended.
Old May 30, 2012 | 08:15 AM
advans's Avatar
C55 ///AMG, 535xi
have u did any wire taps on your shift knob? if you wired it incorrectly, W/C mode can happen all the time. happened on my C320
Old May 30, 2012 | 10:52 AM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
Check the connector for oil seep
Old May 30, 2012 | 12:08 PM
arekux's Avatar
2006 C55 AMG
Nope never touched those...
I haven't done any wire taps...
Old May 30, 2012 | 12:09 PM
arekux's Avatar
2006 C55 AMG
Sorry where is the connector?
Old May 30, 2012 | 12:21 PM
ddtham's Avatar
C32, 911 SC
I think he might be talking about a transmission connector underneath the car that is prone to leaking on w203.
Old May 30, 2012 | 12:28 PM
arekux's Avatar
2006 C55 AMG
Oh ok I look it today...
Old May 30, 2012 | 01:10 PM
Viper98912's Avatar
Yes, I think it's on the front pass corner of the Trans pan, just above it
Old May 30, 2012 | 04:10 PM
arekux's Avatar
2006 C55 AMG
checked the cable near tranny pan, cleaned, it was really dirty, took out car for test drive now car stuck in 2nd gear with cel, seems like I'm stuck in limp mode, need to pull codes, my feeling its speed sensors gone bad...
Old May 30, 2012 | 04:28 PM
mikekuriger's Avatar
2010 C63
Buy this:
http://www.ebay.com/itm/Mercedes-Gen...074b1d&vxp=mtr
it's an easy repair, if you don't mind a little messy work.
Old May 30, 2012 | 05:22 PM
pointman's Avatar
a car that can't do the throttle reset.
Interesting. Mine would randomly switch into "C" by itself, but no issues switching back. It happened a dozen times, but hasn't happened for a while. I had tranny work done right before all this happened. Is this something I can spot easily without pulling stuff down?
Old May 30, 2012 | 11:03 PM
arekux's Avatar
2006 C55 AMG
so i had tranny leak, fixed it today refilled new fluids, new filter, gaskets now seems all ok, i also had cel said something about Incorrect Gear Ratio, which i think because my fluid was low.
Old May 31, 2012 | 11:37 PM
arekux's Avatar
2006 C55 AMG
Tranny started doing the Same thing, sometimes it starts in 2nd then downshifts to 1st gear in manual and sport not all the time, can conductor plate can cause this or speed sensors? I got no cel btw.
Old Jun 4, 2012 | 12:50 AM
pointman's Avatar
Is its official name "transmission connector"? Cause I want to mention this to my deal.
Old Jun 4, 2012 | 03:25 AM
ddtham's Avatar
C32, 911 SC
When I had mine replaced, they called it "tranny o ring."
I had it replaced for 25 bucks if I remember correctly.
Old Jun 4, 2012 | 06:30 AM
Viper98912's Avatar
Yes, it's the transmission connector. There is an o-ring on it that leaks.
Old Jun 4, 2012 | 12:09 PM
pointman's Avatar
Awesome. Thank you gentlemen.
Old Jun 8, 2012 | 01:27 AM
arekux's Avatar
2006 C55 AMG
Unhappy
So my torque converter and pump went bad, did this happened to anyone car is only 06 with 89k miles.
