Bled the brakes perfectly but ESP malfunction...
I've STFF for the last hour and all i can come up with is air in the MC, but to be completely honest that would be literally impossible since I never let the resevoir drain past "min" and that on top of the ESP has me for a loop.
Any ideas? And does anyone know where the MC is located and if it has bleeder nipples that I can check to see if it is indeed full of air?
well then I guess we're all on the same $(*@)(&)(@&$ page! ugh this is frustrating, I seriously DO NOT want to pay some indy shop to diagnose my problem and then basically tell me I owe them $200 for the diagnoses
EDIT: Oh and I forgot to add that my cruise control also doesn't work but I somewhat expected that since it and ESP is on the same system
I would try turning the car on and off 4 or 5 times first (sometimes resets malfunctions), followed by running the car and turning it lock to lock many times (recalibrates esp/abs possibly).
Good luck!
-edit-
Have you driven around with the new brake setup? Driving around with it for a little while might also make the malfunctions disappear.
What does the brake pad to rotor clearance look like? Should be pretty tight (few thousands clearance) without the brake pedal pushed.
and ya i ended up taking to indy shop
The Motive power bleeder's instructions state not to exceed 20 psi. The gauge does go all the way to 30 psi though. I was about to embark on a brake bleed on my C43 last weekend, but didn't go through with it because of the 30 psi requirement in the WIS.
the main reason this perplexes me is because I did this too my 05 C230k, changed pads, rotors, and new brake lines and didnt have this problem
