Change foam in seat?
Fredrik
The seat cover is held to metal reinforcement rods in the foam cushion with plastic clips. You will need a long slender tool to press into the cushion and attach the little clips. I happened to have a similar tool used for latching jetski battery straps, and that got the job done.
I also had to drill out some rivets that hold the air bladder switches to get the cover off, so plan on installing new rivets.
If any of this makes you cringe, you could get an upholstery shop to install the foam. The foam was very cheap for Amg from online parts dot com.
I got my 04clk55 w 20k miles and lower drivers seat cushion was smashed like a pancake....... I suspect orig owner was very dense or lg mass or both.
Take your time when doing this, pull the seat and work on it on a clean area. You have to be gentle with all the plastic parts.
I broke the plastic seat track veneers when putting the seat back in..... They are cheap to replace but still bugged me. Gl
Air hose easy to disconnect. Reconn.
