No reverse...
Old Oct 27, 2012 | 01:29 PM
mpjsols's Avatar
W203 C270CDI
No reverse...
I would be grateful for any suggestions on this one please !
Once of those weeks! Car threw an EML, then when parking, could not select reverse or neutral. Could drive home. Next time , EML On, stuck in second gear, C/S light off on the gear display. If engine off and key out , then restart and could change gear selector.gear change reverse to drive is more clunky if that makes sense.
I think either TCU or speed sensor causing lockout, generic TCU error on OBD-ii ,P0702 - Open or short transmission control module circuit - Poor transmission control module electrical connection - Faulty transmission control module - Transmission control module not coded
On a UK (RHD) car is the TCU on the drivers side, and if so how do you get the carpet from under the throttle without too much dissasembly.
Any similar experiences, it is a low mileages 190K 2004 C270 CDI,
Thank
Old Oct 27, 2012 | 02:30 PM
crazeazn's Avatar
C55
I think you would get a faster response if u posted in the W203 section!
https://mbworld.org/forums/c-class-w203-3/
Old Oct 27, 2012 | 07:21 PM
benzmodz's Avatar
W203 slightly modified
Sounds like hydraulic plate.
