Karlos c32
2003 C32 AMG
Karlos c32
Hey guys. I'm new on the forum and decided what better way to introduce myself. So I went with opening up my cars upgrade thread.
So far my car is stock. It has a res delete and a double din install.
I have ordered some KW v2s and ghost riders rear camber kit.
Hopefully these goodies are in by the end on this week.
I'm planning on making a DIY for both. And will make and edit a video on how to install. Also planning on giving a review.
2003 C32 AMG
^ since the winter is approaching soon
I would like to lower it a little bit.. i want to get rid of the front tire gap. and in the summer time i will have to see with what rims i will be getting.. but i like my cars low
2003 C32 AMG
here is some shots of the LEDs i added to the car.
small things matter
this is the picture of the led wedge inside the headlight
small things matter
2002 C32 AMG
Nice, another Canadian. Where in Ontario are you from?
BTW, used the exact same LED's in the interior dome lights. I tried them out on the license plate as well but found them way too bright so I went back to stock. Nice clean ride. Can't wait to see it slammed.
Bry
Bry
2003 C32 AMG
Bry
Bry
i like them for the licence plate. they are bright but its better than before
i cant wait to slam it
they were like 15 bucks with free shipping and came within 10 days
2003 C32 AMG
here is the link for both of them if anyone needs them
http://www.ebay.ca/itm/License-plate...#ht_2809wt_986
http://www.ebay.ca/itm/No-Error-9-SM...#ht_2912wt_986
Enjoy the kompressor life
2003 C32 AMG
Guys i wanted to know how low i will be able to go on my stock wheels, without using spacers.
Tried to look for this but i had no luck
KW front springs are 285mm freelength
H&R front springs are 245mm freelength
2003 C32 AMG
no spacers I can tuck my front tire on my stock C55 wheels with 1.5inches left of drop on my KW's but.....I also using shorter front coiloversprings from H&R which allow for that fitment on stock and my Schmidts,it's your choice bc spacers and bolts cost the same or more than new fron springs and you still wont get the drop you want
I will have to decide between these two options.
It raises some questions.
Are the springs the same? how do they compare on the road?
same compression rates stiffness such and such
i will have to look into it.
How much were the front 2 springs?
KW fronts 39 N/mm 285mm freelength
108-142-685
H&R 52 N/mm 245mm freelength
cost me $170 shipped from my German supplier
keep in mind that is static weight one can have a higher progression weight
2003 C32 AMG
It looks like i will be needing spacers.
Im trying to see how low i can go with it being "safe".
I will try and take some photos.
my tophat seems to be spinning also.. is this normal?
