Rear Spacer confirmation- input please!
Old Jan 27, 2013 | 10:21 AM
precisionmike's Avatar
2003 C32
Here is the deal on the rears:
C32
big drop
9.5 rear wheel
265/30/19
+40 offset
rolled fenders, bumper tab removed
Do you suggest 10mm spacers? I know the front spacers are very particular to our cars, but are the rears easier to find? TIA, Mike.
Old Jan 27, 2013 | 10:43 AM
c32///'s Avatar
C32 AMG x 2
you might rub, I'm not dropped, 18" 9.5 rears fenders rolled 15mm spacer 255/35/18 pilot sports and I rub with 3 people or just on some pot holes. It also depends on your tires, i had conti's before and the walls are shaped differently than the pilot sports. as for spacers, you can find pretty much anything on ebay from cheap no name to H&R, around 100$ for a decent pair.
Old Jan 27, 2013 | 11:02 AM
2003 C32
Thanks for the quick response. As I am researching, it looks like 5mm may do the trick. I have +35 offset 19x9.5, 245/35/19 now (about to change rims/tires) and the wheel is failry close to the fender. I will be using vderstein ULTRAC SESSANTA tires, I hear they are somewhat round. Also, if my wheels have a center bore of 66.6, I will not need inserts, correct?
Old Jan 28, 2013 | 02:31 AM
johnng117's Avatar
2002 C32 AMG
Correct.. 5mm you should be clear.
