Brake wear sensor replacement DIY
Old Feb 19, 2013 | 12:00 AM
Choppy AMG's Avatar
2003 C32 AMG
Hi Guys,
Brake wear error been coming on alot lately. I ordered the sensors and would like to know how I go about replacing them. Has anyone done this diy. Please share your experience and tips.
Old Feb 19, 2013 | 12:20 AM
saer1one's Avatar
2002 c32 AMG 2012 c250 Coupe
Front sensor located on right side, rear sensor located on right side. Jack up car, remove wheel, pull sensor out of brake pad and remove from sensor plug. Install new in reverse to removing but may I suggest you replace brake pads as the sensor is telling you pads are low.
Old Feb 19, 2013 | 12:28 AM
Choppy AMG's Avatar
2003 C32 AMG
Thanks for the info. Front disc and pads were replaced not too long ago and still look good. The error comes up even when not braking and when i clear it it will pop up again before i even brake.
Old Feb 19, 2013 | 12:31 AM
saer1one's Avatar
Ok so sensor is worn just replace with new and you should be good to go..!! Good luck..!!
Old Feb 19, 2013 | 04:25 PM
lkfoster's Avatar
’27 AMG SL55(ordered), ‘23 EQS 580 SUV, ‘19 AMG E53 Cpe, ‘48 Willys Jeepster
Or jumper the connector with a paperclip if you're frugal.
Old Feb 19, 2013 | 07:07 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
make sure your pads are fine
