Halogens to HID questions
I know when installing the bi-xenons you have to have the system set for them to accommodate the bi-xenons. I'm assuming you will still need to do this if you replace the halogens with HIDs while retaining the halogen housings because you'll still be running at 35w and not the factory 55w. Is this correct?
If the settings must be changed, can you still run the halogen bulbs with the computer set to accept the HIDs?
Just want to double check so I don't go to install the HIDs and get stuck with no lights and Vic versa.
TIA!!
I'd still like to know if I changed the STAR setting to bi xenon if the HIDs would work without the error canceler and if the halogens would still work with the setting switched over.
