C55-06 TCU in CLK 55-04
00 C200 & 00 C55 & 06 SLK55
I think 03/04/05/early 06,, got the same Can bus,, the 06 C55 TCU/EGS52 works fine with you,
cause both cars uses "3.06" diff., with Can of ME2.8 or ME2.8.1, both reading the same software,,
That’s why you don’t need to program it, both sharing the same data/file of "3.06" End Ratio.....![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
ZAYED,,
ZAYED,,
ZAYED,,
ZAYED,,
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
You brought a brilliant idea...
,, guys should uses that...
Every TCU adapted & programed of the oil pressure of the Solenoids in the Valve body & every shift of the diff. ratio & the Authorized Starer signal to
the ECU through the Tip. shifter,,
The good thing of 03 to early 06, that all except the data/file & DAS between them, that can be done easily by Star/SDS....![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
ZAYED,,
![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
ZAYED,,
ZAYED,,
ZAYED,,
