255s rubbing! Need healthier friends!!
Ok, so I had friends visiting this last weekend- Decided to take everyone out to the range in the C55. Four people including myself with munitions and peripherals in the trunk (not a whole lot) Big friends tho
Under about 3/4 acceleration from a light I hear this shrill whine coming from the right rear. I let off and pace the sheep the rest of the way- upon arrival I discover shavings of the sidewall hanging off from rubbing the inner fender!
What gives?
I am running 40 series 255s in the rear (PO installed)
They are Bridgestone Potenza re760s
Anyone ever rub with 255s?!? I could expect this with 265s, but damn!
What gives?
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
Given how much weight you had on there, you may have rubbed with the standard 245's! I wouldn't worry too much. Just drove to Miami and back to VA with about 3-400lbs combined in the trunk and back seat and I rubbed on big bumps every now and again. And I'm running 255/35's.
Damian
Damian
I think your 255/40s have a bearing on the rubbing issue. Proper 255 fitment should be 255/35s.
Or perhaps you need the 'no fat chicks / car will scrape' sticker?!?
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
Boy, the car pulled like a raped ape when I went to work solo the next day
I wish my PO bought 35 series like he should have- next round Ill go 255/35s then.
Thanks for the input guys!!
yeah - I kinda wish I needed tires (never thought I would say that) but having taller tires in the back bothers my OCD side. Buying tires on my girlfriends vw this weekend has me itching to replace mine. Anybody have luck with a particular tread/brand on these cars? My experience is mostly on lighter imports/aircooled
cheers
cheers
cheers
cheers
feel greasy compared to the Micheline Super Sports I picked up on sale. I could get the rear kicked out pretty easily on one particular turn and have yet to do so trying a bit harder on the SSs. Super Sports are noticeably quieter too, even w/ what may be stiffer sidewalls. I can run less pressure in the Super SPorts compared to the V12s too. V12s were mush until I nearly maxed out their pressures and then the ride was horrible.
Ive had Hankooks before and I liked them a lot
C32, 911 SC
I moved the tires from another wheels that I have. I would definitely go with 265/35 for my next set of tires.
I do however liked the slightly thicker sidewalls and my solution is to not give a ride to more than one person at a time
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
Now, I'm running 255-35-18 and it's perfect!
I would love the extra traction of 265s on my C55, but with this rubbing (though I'm sure its 40series related) I am scared off them. These cars need all the contact patch they can get!
The previous owner put these BFGoodrich g-force sports on my car but at least got the right size by putting 255/35ZR18 rears on the factory rims. They are really good even with four passengers and heavy shopping in the trunk. They cost about the same as Hankook Ventus v12s but they are not nearly as popular as the Hankooks. I think they are fine but I am no tire expert, they look cool though. http://www.tirerack.com/tires/tires....m=535WR8GFSPC2
Thanks for the heads up
good looking out - thanks!
