C55: Lots of issues, need help! Steering wheel stuck, headlight flickering, brakes!
Old May 14, 2013 | 04:31 PM
ryad32's Avatar
C63, C55 (sold), 2002 C32 (sold)
Hi all,
Ive been having a lot of issues with my C55. They didnt happen all at once but im planning on fixing them all now. I need advice and help on how to fix these issues, and how expensive they are, as well as where I can fix them or how I can fix them for the least money.
1- Steering wheel is stuck in the upper most position. My steering wheel no longer auto adjusts on its own. One day, I got in the car and I could hear the leveling motor working but the steering wheel isnt moving downwards. It moves in and out but doesnt move up or down. How expensive is this to fix??
2- My right side low beam headlight flickers and goes out all the time. Usually within 2 mins of driving or any sort of bump on the road causes the bulb to go out. If I hit a pot hole or bump in the road sometimes it will cause it to flicker back on but for the most part the lights turn on when I turn on the car and then the right low beam bulb goes out shortly after. When im driving, my simple fix is turning the lights off then back on which turns both headlights back on. I think others have had this problem as well. Is it the ballast? i donno, but how much is this to fix?
3- I need to replace my front pads and rotors? What are the cheapest/best brand? Where can I get them?
Im planning on selling my car when I get all these issues fixed so im trying to save as much money as possible on all these repairs. Your advice and expertise is much appreciated guys!
Thanks!
Old May 14, 2013 | 05:50 PM
Quickvr4's Avatar
05 C55 AMG
My advice is not to cheap out on parts...
Old May 14, 2013 | 05:51 PM
pointman's Avatar
a car that can't do the throttle reset.
stff
Old May 14, 2013 | 07:57 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
1) broken dogbone
2) connector, ballast, or bulb (in that order)
3) OEM, Zimmermann, there's a ton of them out there if you search auto parts websites. rotors aren't that expensive
Old May 14, 2013 | 09:02 PM
Drummajorc's Avatar
W203 C320, W208 CLK 320, w209 CLK 500
Here's a thread that goes into the steering wheel issue.
https://mbworld.org/forums/c-class-w...d-working.html
As stated, its because of a broken dogbone that links the adjustment motor to the steering column, its a pita to get to and requires removal of the driver side dash. The part itself costs about $3, but a shop will probably charge $500+ to tear into the dash to fix it.
Old May 14, 2013 | 09:27 PM
pointman's Avatar
Old May 15, 2013 | 01:43 AM
PelicanParts.com's Avatar
SPONSOR
Answer
Originally Posted by ryad32
Hi all,
Thanks!
Pelican Parts has many price levels to select from.
http://www.pelicanparts.com/catalog/...570-Brakes.htm
whunter@pelicanparts.com
