OEM bosch ignition wire question!!
Old Jun 1, 2013 | 11:35 PM
raf12690's Avatar
c32 amg
Just received my Bosch ignition wires set part# 09849 from Amazon and had a couple questions. I received 6 wires part # ending in 948 (all labeled G), 2 #052 (labeled G), 2 #050 (Labeled K), and 2 #054 (labeled K). So a total of 8 "G" labeled wires and 4 "K" labeled wires. I was assuming that I would need 6 of each. Only opened cylinder 4's (front right looking front) and under the coil it said where the G went and where the K went.
Are there two cylinders that use only G cables? Or did they screw up the shipment? Also does it matter which "K" labeled wire or "G" labeled wire goes where? Or is any G or K wire good to fit in any G or K labeled position.
So confused on which wire goes where. Are the different part# G wires different from each other?
Old Jun 2, 2013 | 03:03 PM
raf12690's Avatar
c32 amg
did cylinders 4,5, and 6 just now and cylinder 5 uses 2 "G" wires, so I'm pretty positive that cylinder 2 does also.
