antenna amplifier module
c32 amg
Has anyone replaced the antenna amplifier modules. My key fob would not work last night,figured the battery had died. Replaced battery,no change. Also radio reception greatly degraded. The key fob apparently sends both an infrared signal to the door handles and an RF signal to antenna module 2 in order to activate the central locking system. I checked fuse 8 in the trunk which is the line fuse for the antenna amps and it was blown. I plugged in another fuse and it promptly blew. Im assuming the amps have crapped out.I think they are located under the left C pillar. Any info would be greatly appreciated. thanks dusty
