C32 Quad Ram Air Intake!!
Rating: Thread Rating: 4 votes, 5.00 average.
Old Sep 10, 2013 | 08:25 AM
  #51
amx1397's Avatar
05 crossfire w/SL55 drivetrain installed by Rudy Compart Intake/Needswings best et-10.76 @ 129
I know this cost more than yours but this thing really works. the flow test shows it flows over 400cfm more than stock. good luck which ever way you go. jim
http://www.needswings.com/ProductImages/c32dcais.jpg
http://www.needswings.com/NeedsWings...t-c32dcai.aspx
then go to c32 then go to intake.
Old Sep 11, 2013 | 05:51 AM
  #52
swedepat's Avatar
2011 C63 AMG, 589hp
remember guys.
grinding the throttleaxle will give you about the same area as an 78mm throttlebody.
And, with the advantage of that you dont run up and down in area, in other words: keeping the speed of the air.
Old Sep 17, 2013 | 01:47 PM
  #53
JamesC32's Avatar
2003 C32 AMG, 2015 RAM 1500 4x4, 2012 Merc GL450
filter
There's a foam dual type Ramair filter in the Y, its a cut to fit filter, there is a ramair website that sells them, suppose to flow and clean better than the K & N's, that what they say anyways.
Old Sep 17, 2013 | 02:37 PM
  #54
JamesC32's Avatar
Ramair-filters
RamAir are famous for their consistent "Best in Class" flow rates and dirt retention (not to mention their continued dominance in Motorsport) This means with the RamAir filter you are sucking in as much air as possible with the knowledge that no other filter can supply such pure, uncontaminated air as your RamAir filter.
Every RamAir filter is made by hand in the Uk, they are a true testament of quality, precision and are a bench mark for the competition to try and match. You can purchase from us with total confidence, you are buying the best straight from the factory. We are not a reseller of this item we are Ramair.
Product Details -
300mm x 200mm x 15mm Universal cut to shape panel of twin core Ramair Aeriform foam. This is ideal for custom air box applications. Simply cut to size and locate in airbox as desired.
Ramair twin core foam is unique and like no other in the market. It is impregnated with a polymer retention agent to give maximum dust filtration along with optimum performance. Don't accept anything less than the best for your engine. Use Ramair!
Any questions regarding this product please call 01980 623401
Other sizes and fitments available. Please enquire
Length
Width
Thickness
300mm
200mm
15mm
Other sizes and fitments available. Please just ask!
Tests carried out by MIRA show many Ramair foam filters to out perform rival manufacturers such as and K&N by up to 40%
· RAMAIR filter systems have been technically designed and developed to increase the air flow which maximises the engine's performance.
· The engineered design of the induction system will give more power and torque.
· Ramair induction system gives you an improved engine bay look and a superb induction roar.
· Fitting instructions included to ease DIY fitment
· Comes with full fitting kit included with instructions.
Old Sep 19, 2013 | 12:55 PM
  #55
JamesC32's Avatar
Just saying
Its nothing like a soccer sock!!!
Old Sep 19, 2013 | 01:05 PM
  #56
JamesC32's Avatar
So Paqueres
You have a hard time seeing the existing filters still working and you think theres a socker sock envolved, you cant see any good ideas here??
Old Sep 19, 2013 | 02:58 PM
  #57
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
You don't honestly think posting the company's own jargon is going to change how air flows. And maybe they're right and their filter flows better than any filter ever made, but that won't make your design flow any better than stock.
Old Sep 19, 2013 | 04:43 PM
  #58
JamesC32's Avatar
L8 apex
I was just trying to show that its not a soccer sock type filter, and you don't have to be an expert to see that it will get more air than stock!!!
Old Sep 19, 2013 | 04:49 PM
  #59
JamesC32's Avatar
L8 apex
If you read some of the posts you would see what some of the other DuM&SS are thinking and know what I'm trying to show yall!!!
Old Sep 19, 2013 | 06:41 PM
  #60
firstshadow's Avatar
03 C32 AMG
This is his filter for his bypass :
Whether it adds power or not, we won't know. No before/after dyno and no before/after quarter mile times???
IMO, the tubes he's using must create a lot of turbulence and it adds little/no/negative power.
Old Sep 19, 2013 | 07:11 PM
  #61
JamesC32's Avatar
firstshadow
How can you see turbulence? It goes in right at the center of the throttle body, it doesn't interrupt the other air flow what so ever till the throttle body, if anything it directs the air coming in through the stock intake! like the stock intake baffle does..
Old Sep 19, 2013 | 07:15 PM
  #62
03 C32 AMG
This vacuum hose won't flow smoothly at all.
Old Sep 19, 2013 | 07:23 PM
  #63
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
This is all speculation on your part. The air coming in from the OEM intakes may be disturbed by the air coming in through the Electrolux tubes or even attempting to escape through these tubes (speculation on my part).
Stop racing using your keyboard and post some 1/4 mile runs. Don't waste your money on any dyno since your setup needs some level of air velocity to have a chance. The usual dyno fans will not do the job. My advice (FrankW said the same thing) if you want to keep things OEM, get a 55 larger T and leave it at that. I do however give you an A+ for trying something new.
Old Sep 19, 2013 | 07:27 PM
  #64
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
I'm not going to go into the air flow benefits but why would you bypass your air filters?
Old Sep 19, 2013 | 07:31 PM
  #65
JamesC32's Avatar
Intake
Code 3 was DYNO proven to increase hp, it was completely open and did not cause turbulence, only flaw I seen was if it could just get cooler air, so how could this be any different from a code3? this is the same but just has a place to pull a little cooler air from..
Old Sep 19, 2013 | 07:46 PM
  #66
JamesC32's Avatar
Ausmbtech
Can you not tell that they are not bypassed?? They are still there working, These are just EXTRA air tubes going in to the throttle body! How can this be that difficult to understand?
Old Sep 19, 2013 | 07:47 PM
  #67
JamesC32's Avatar
WOW!!
How can extra air at the point of entrance give less air? Impossible!!
Old Sep 19, 2013 | 08:10 PM
  #68
cm60k's Avatar
Jim,
Your idea is good, but important to know that, the ECU counts the air velocity/density,
if you open another air bath from the "Y" type(which is soo sensitive area) will not helps the air to comes in the
intake in proper velocity, the air that comes from above area (which you done) will clash to each other every time when
you increasing the speed,,
more air NOT always helps, it depends to the mass of air or the speed density of the ECU data/file.....
ZAYED,,
Old Sep 20, 2013 | 02:18 AM
  #69
swedepat's Avatar
2011 C63 AMG, 589hp
Originally Posted by swedepat
the turbulence gets out of control and actually restrics the pipe.
quoting myself to show that yes! adding random hoses CAN actually restrict the std tubes, with adding turbulence.
But does your buttdyno say the car runs harder, then it is
Your new added hoses does have filters mounted in the front of the car(not visible on photos)?
Old Sep 20, 2013 | 06:08 AM
  #70
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
I chuckled at this.
Old Sep 20, 2013 | 09:57 AM
  #71
Ausmbtech's Avatar
So explain to me how the air going through these tubes gets filtered........
Old Sep 20, 2013 | 12:04 PM
  #72
Pansu's Avatar
"World fastest" C32 AMG
The answer to this have already been written many times, have you read this topic
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
