Speedriven Billet Trans Pans
Old Dec 30, 2013 | 05:09 PM
Speedriven1's Avatar
Speedriven
Speedriven Billet Transmission Pan for 722.6
Our new redesigned trans pans are now available for purchase. After testing the pan we have found many improvements over the stock one.
+Added cooling features for improved heat dissipation
+Larger capacity for trans fluid
+Serviceable with oem filter and gasket
What's included
-Billet Trans Pan
-Trans filter
-Trans pan gasket
-Associated hardware for mounting
-No modifications are needed, simple plug and play application
Color's(anodized)
-Clear
-Black
-Gold
-Red
-Blue
Price
$580 + shipping and handling for uncoated
$600 + shipping and handling for anodized
Old Dec 30, 2013 | 09:02 PM
durableswedish's Avatar
2002 C32
How much of a capacity increase over the factory pan? How much added cooling using your aluminum one?
Old Dec 31, 2013 | 11:14 AM
Speedriven
Almost 2 quarts. It allows the trans to stay a proper operating temp for much longer periods of time when under hard abuse or racing
Old Jan 2, 2014 | 12:14 PM
Speedriven
Pictures installed
Old Jan 9, 2014 | 05:16 PM
Speedriven
Some pics of the kit without filter and gasket
Old Jan 10, 2014 | 11:05 AM
Speedriven
Old Jan 21, 2014 | 11:01 AM
Speedriven
updated pics
Old Jan 21, 2014 | 03:18 PM
Speedriven
Another one with machined Fins
Old Mar 11, 2014 | 02:21 PM
Speedriven
Update pics!
Old Jan 20, 2015 | 11:11 AM
Speedriven
Old Feb 2, 2015 | 02:03 PM
Max Thrust's Avatar
G's + 190
Nice looking pan, looks well designed, very precise.
How will it compare in an impact to the steel one? Such as running over road debris, etc.
Does the anodizing have to coat the inside of the pan as well, or no?
Old Feb 2, 2015 | 02:51 PM
Critter's Avatar
07 E63 + 07 CLK63CAB
Speedriven1, Just when will you consider a group buy for your eager customers, lets go ***** out and try for 20 pans. 55 and 63 models
What do you think??
500 a piece
Old Feb 3, 2015 | 02:04 PM
Speedriven
The pan weighs in at 4.1 lbs so its got a good amount of material. Roughly 0.1 inch wall thickness. We have pulled a trans with the pan installed and it holds up the weight of the trans with no issue or any signs of stress marks. It is made out of a solid billet piece of 6061-T6, not cast piece that gets machined.
I would have to contact the anodizing guy and see what he can do to avoid the inside getting anodizing.
What do you think??
500 a piece
Game on.
Start a list and lets get a group buy going.
$500 anodized for the 722.6
$570 anodized for the 722.9
Min of 10, if there is more than 10 that commit we should be able to get a better break on the billet stock and we can get the price a bit lower.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
Old Feb 3, 2015 | 02:26 PM
Critter's Avatar
1. Critter E63
Old Feb 6, 2015 | 06:18 PM
a100steaksauce's Avatar
W218
Originally Posted by Speedriven1
Pictures installed
what vehicle is it on in these pics?
