3000 stall converter in stock!
Old Mar 4, 2014 | 11:26 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
We have one 3000 stall converter in stock that is set up for the power range of the C32 /722.6 trans.
This is not a re-worked stock converter but a custom built, smaller, lighter 3000 stall with triple lock up clutches, custom pump and set up for the c32.
PM me if you are intersted and will make you a good deal.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Mar 13, 2014 | 09:35 AM
PLATINUM SPONSOR
2003 CL55
Still in stock and PM me i fyou have any questions.
__________________
www.ultimatepd.com
