Will SL Wheels Fit Our C32s (in sizes, offsets listed)?
Old Nov 24, 2003 | 07:58 PM
Accomplice8's Avatar
xx
2003 MERCEDES AMG SL55 WHEELS AND PIRELLI PZERO ROSSO TIRES. THEY ARE STRAGGERED 18 X 8.5 FOR FRONT WHEELS AND 18 X 9.5 FOR REAR WHEELS. THE OFFSET IS 30MM FOR FRONT AND 33MM FOR REAR WHEELS. Would these work on a C32?
Kevin
Old Nov 24, 2003 | 09:32 PM
kaze81's Avatar
Mercedes
I don't think it will fit cos of some reasons.
1. The diameter of SL wheel is 14mm( correct me if i'm wrong) while C32amg diameter is 12 mm.
2. The offset isn't gonna fit.
I might be wrong but that's all I can tell you
Good luck
KZ
Old Nov 24, 2003 | 11:00 PM
Harris's Avatar
The offsets are good. The only problem is the SL uses 14mm BOLTS and the C32 uses 12mm BOLTS. However, you can use your car's 12mm bolts with the SL55 wheels. It would work, just not highly recommended.
Old Nov 24, 2003 | 11:12 PM
E55AMG99's Avatar
1951 Caterpiller D6
Yeah, clamping force is greatly reduced.
I finally gave up searching but I read someplace about 12mm bolts with 14mm seats.
