Warped rims?
Old Mar 8, 2014 | 06:21 PM
Richardmozis's Avatar
E55 AMG
Warped rims?
My two rear rims had a very similar amount of wheel weights between each other. I never noticed any vibrations etc..
At the tires shop fitting new tires, I saw the tire press slip off the tire and hit the driver's side rim hard, then other employees came in to help him manhandle the tire onto the rim.
The guy in the tire shop called me in later during balancing to show me that my wheel was warped, I said that it could have happened just now... This wheel isn't curbed or hit like the passenger's side rim. He said it was an AMG rim, it couldn't have been bent.
I tell them to just finish the job and finish balancing that warped rim
Now I have much bigger and more wheel wights on the driver's side vs. passenger's side
Could the rim have been warped before and I just didn't notice it or would it be possible to bend the rim slightly while installing a tire. - car seems to drive the same now
Old Mar 8, 2014 | 07:45 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
Without the weight of the vehicle and amount of impact force like a road surface pothole, I doubt that a crowbar or whatever tool they were using could have dented the wheel that severely. If anything, just lots of echo....
When it comes to balancing, most of the time it isn't the wheel that's out of balance, it's the tire. All of my wheels/tires have differing amounts of weights on them. I think you're ok, unless you can feel the vibes on the highway. And unless you're driving a black series, or 150k+ AMG, those rims are the same as any other; they're not forged.
Old Mar 9, 2014 | 04:44 AM
Saaboteur's Avatar
eclectic assortment of cars
I've used tire mounting machines before - the tools used to flip the tire bead onto the wheel are simple hand tools, much like a small pry bar. I'd echo Viper and say that one of those hitting the wheel is unlikely to bend anything.
But you were saying that the press hit the wheel - was this when they were dismounting the old tire? The bead breaker is usually pneumatically operated, and does require a bit of force to do what it does.
Old Mar 9, 2014 | 04:42 PM
E55 AMG
I'm not an expert on tire installation.. however, the manager of the place told me to come back during the week and he will have that wheel straightened & refinished. The guy who installed the tire was a 'new employee'.
