Odd behavior after repair involving fuel line disconnect?
This weekend I changed the valve cover gaskets and the SC pulley bearing in my fiancee's 2003 C32 AMG. Everything went very smooth, but I did have to disconnect the Fuel line going to the rail to access the driver side valve cover (and a good little amount of fuel came out). Upon initial start after the repair, you could hear the rail pressurizing and the car started fine. While she was out she made a stop at a friends house and upon starting the car when she left she said it was revving high as if you were pressing the gas pedal but she wasnt, so she turned it off, restarted it and it was fine. Then on the way home she said there was a time where upon acceleration there was a moment between shifts (it an automatic) that it seemed fuel starved as if she needed to press the pedal to give it gas but this seemed to do little until it shifted it seemed to recover. I test drove it when she got home and it seemed fine (of course right!).
I am just curious if this could be an after effect of having disconnect the fuel line before the fuel rail during the repair and maybe there was air in the line or something? Should this work itself out? Then again it could be just a coincidence, any thoughts?
