Any way to check C55 motor mounts?
'12 Mustang 5.0, '89 Supra Turbo, C55,
Hi. I'm getting a vibration while in drive at idle, and research makes me think its the MAF or motor mounts. I will clean the MAF first, and see if that helps, but is there any way of visually inspecting the motor mounts? Thanks.
1999 E320 4matic Wagon, 2005 C55 AMG - sold, 1998 VW Jetta TDI - sold, 2006 C230 Sport - Totaled :(
If you don't have a second person to do what shardul suggested, you can also see if they are leaking any fluid. Usually one will go a little bit before the other but since you're going to be replacing one and doing all that labor, you might as well replace both at the same time.
