Is there a way I can tell if my car has a tune?
Thanks!
Not sure I will be able to tell a difference as this is the only C55 I've ever ridden in. But I'll give it a try.
Not sure I will be able to tell a difference as this is the only C55 I've ever ridden in. But I'll give it a try.[/QUOTE
Even better. What is your gas mileage? If you drive 65mph ont he freeway and try to get the best gas mileage you can...OEM tune will be around 22mpg. The Eurocharge tune should let you see 22-26 mpg. I have gotten 26mpg before.
My average gas mileage between city and freeway is 18.9 mpg.
Not sure how much of an impact the larger wheels makes on mpg. They came with the car. I'd ideally like to use the factory 18's I have. I'm planning on running winter tires on those though. Are we able to clear the front brakes with 17" wheels or is 18" the smallest we can go?
Thanks for the info!
PS. Is there any kind of OBDII scanning tool that would be able to look up any code/value changes to key me into an aftermarket tune?
There used to be a noticeable flat spot before the tune where the power would not continue to increase above 5k rpms. After the tune the car continues to pull harder up until redline.
Thanks again for the info!
Remember that C32s ran 17s, and the brakes are the same as on a C55, so if you can grab a set of C32 wheels, you'd be good to go. So 17" AMGs wheels from CLKs, SLKs and other C classes of the same vintage should work.
In my case, I was just shopping for winter wheels at the time and happened upon that set I eventually bought. They were just a simple five spoke AMG, if you see the first page of my C55 thread, there are photos.
