Clamps on fuel filter?
Old Sep 25, 2014 | 04:19 PM
c32used's Avatar
LET C32 2002
Does anyone know the sizes of the 4 clamps that is used to attach the fuel filter for a C32?
Old Sep 25, 2014 | 04:59 PM
cm60k's Avatar
*1 clamp = 10mm
*2 clamps = 14.5mm
*1 clamp = 17.5mm
ZAYED,,
Old Sep 25, 2014 | 08:33 PM
c32used's Avatar
LET C32 2002
Question
Originally Posted by cm60k
*1 clamp = 10mm
*2 clamps = 14.5mm
*1 clamp = 17.5mm
ZAYED,,
thanks
is this thread good to cover fuel filter change on the C32?
https://mbworld.org/forums/c-class-w...placement.html
if so only question left is where do I release fuel pressue since above thread refers to C230k
Old Sep 25, 2014 | 09:57 PM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
The instructions are ok and also apply to the C32. Skip step 1 and just remove the fuel cap to relieve any fuel pressure. Depending on the kind of jack you use, you may need to remove the rear driver side wheel. You may get by without removing the "belly pan" aka cover below main floor, left. Just undo some of the plastic nuts in the back. The rest is a simple remove and replace. Check for leaks. Turn the key twice to position 2 without starting to prime the system. Then start the car. Good luck.
Old Sep 26, 2014 | 11:50 AM
c32used's Avatar
LET C32 2002
Talking
thank you very much Lenin
your help has lead me as far as I've gotten.
Old Sep 27, 2014 | 12:37 PM
ez53436's Avatar
C 32 AMG & FG2 Civic Si
just did this on my C32, not difficult at all. the only parts that are slightly annoying are getting all the stock clamps off the hoses that feed in and out of the fuel filter and all the gas that spills out isn't too fun either. good luck!
Old Sep 28, 2014 | 01:23 PM
c32used's Avatar
LET C32 2002
Old Oct 20, 2014 | 09:39 PM
fleishman's Avatar
2002 C32 AMG
I just changed mine yesterday. Easiest way to remove the old clamps without the correct tool is just a tiny screwdriver to pop them off. Don't have your face in the way a bit of fuel leaks out but it doesn't keep running out.
This pack of assorted fuel line clamps from Oreilly's fit all three sizes! http://www.oreillyauto.com/site/c/de...0189&ppt=C0075
