Dash Display
C32 AMG
Dash Display
I don't seem to have the option of displaying the outside temperature in the bottom left corner of the dash display. It always displays speed in km/h. I wonder if I have an older version (my car is a C32 registered 06/02), but the manual indicates I should be able to show the outside temp.
Can anyone help?
Can anyone help?
Living in UK,
Maybe your car doesn't want to disappoint you![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Settings
Instrument Cluster [Down Arrow]
Select Display (Speed or outside temp)
Text Language
Display Values in
Temp (C or F)
12/24 Clock
Set Minutes
Set Hours
You may want to play with the Text Language above, but more likely you car is set to a specific "Country" in the DAS software that doesent provide outside temp as an option. (see dealer for that)
Settings
Text Language
Display Values in
Temp (C or F)
12/24 Clock
Set Minutes
Set Hours
C32 AMG
Settings
Select Display (Speed or outside temp) - THIS DOESN'T APPEAR!
Text Language
Display Values in
Temp (C or F)
12/24 Clock
Set Minutes
Set Hours
Are there different versions?
Text Language
Display Values in
Temp (C or F)
12/24 Clock
Set Minutes
Set Hours
likely you car is set to a specific "Country" in the DAS software that doesent provide outside temp as an option. (see dealer for that).
Here are some of the settings I have heard of:
US
ROW (rest of world)
Netherlands
Each has some nuances (+/-) , so good luck you may have found a bogie in the UK version, for example.
US
ROW (rest of world)
Netherlands
