Winter cold is coming here in Sweden and since I am going to Norway skiing in really low temperature I'm getting a little concerned with my battery. I only get 12.0 when measuring directly on the battery. Should I get it replaced? I do get the normal 14.4 when the engine is running so no problem there.
/frejo
/frejo
It's a little low, if your concerned you should change it as a dead battery will cause a lot more problems in the mountains.
