C55 tranny upgrade to 722.9 (7 speed)
Old Apr 1, 2015 | 06:08 PM
TobiasMB's Avatar
10 C63/p31, 84 190/5.8L, 14 Audi Q5 TDI, 03 Suburban /8.1, 87 Porsche 944/358" 77 Ferrari 308 Dino
Curious to know if anyone has done this upgrade and if so, how did you accomplish the wiring harness to work properly.
Thanks for any help...
McGyver
Old Apr 1, 2015 | 07:35 PM
cm60k's Avatar
It's definitely interesting, didn't know anyone done this, hope someone does..!
i think it can be done if copying everything including harness from (2005-2010 SLK55 AMG),,
C55 sharing the same diff. ratio with SLK55 as well..
ZAYED,,
Old Apr 1, 2015 | 09:58 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
Remember you're gonna need ECU/TCU programming as well.
How about just buy CLK63?
Old Apr 2, 2015 | 03:30 PM
///AchMeinGott's Avatar
none... for now
Easiest/most expensive way- Buy motor/trans/ECU/TCU
Easy/less expensive way- Buy trans/TCU
Either way, you're looking at a custom length driveshaft I'm assuming, unless the SLK/C share a driveshaft somehow.
Side note. Despite being a 2 seat sports car, the SLK was less then 100lbs lighter then the C55(hard top vert will do that). Even with the 7 speed and weighing less, the SLK55 and C55 are rated the same MPG, although I'm sure real world they aren't.
Old Apr 2, 2015 | 04:11 PM
husqvarna's Avatar
C32AMG
722.9 hase the TCU built inside the tranny! So will need a lot of wirings, and for me is pointless
Old Apr 2, 2015 | 04:45 PM
TobiasMB's Avatar
The driveshaft is not a problem, done many and even the axles in my 190 (201) are Spicer driveshafts, the same as in a one ton truck! No problem ever with 450hp going to them.
I'm working with Sun Valley Mercedes for their 722.9 but still need to work the wiring out. Also have a 09 CLS 63 motor lined up so would like the 7 speed for it.
Anyone have any experience doing the swap?
Old Apr 5, 2015 | 03:23 AM
JonMBZ's Avatar
06 C55, 09 E350
7229 is a terrible tranny. I would stick with the 6, not that it's an option anyways.
Old Apr 5, 2015 | 07:11 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
+1 I have been hearing the same thing
