c32 broken crank position sensor
Old Jul 7, 2015 | 04:43 PM
e55izm's Avatar
040 w201 55 sold 040 w210 wagon 040 w211 55
stuck in the housing. i tried drilling it. Tried chipping it away. got about half of out but now I'm at a stand still. any advice appreciated.
Old Jul 7, 2015 | 08:36 PM
Supgee's Avatar
2003 C32 AMG
Honestly worst case scenario is removing the transmission and pushing the sensor out from the inside of the bell housing, I know it's not something you wanted to hear.
Just went thru this problem today with a seized coolant temp sensor actually, and I was able to finally free it by bending it up around the "edges" and eventually jamming a long snap on pick in there and yanking it out with copious amounts of penetrating oil and swearing.
I know the crank sensor is in a PITA position to get too, but try using penetrating oil and a long pick that is strong that will dig into the plastic and can be used as a lever.
Good luck
Old Jul 15, 2015 | 02:59 PM
e55izm's Avatar
thanks for the time brother. i just got the car a few months ago. previous owner had a busted radiator hose instead of changing the hose the dummy just kept adding fluid and ran the car hot causing the cps to damn near melt and bond to the metal of the bell housing. last weekend i was able to drill thru it i just need to clean it out now. any idea on how to retrieve the magnet and shavings that fell in without removing the tranny? not a mechanic just a diy'er who doesn't mind getting dirty but patience with this cps has well exceeded my limitations.
Old Jul 15, 2015 | 08:41 PM
Supgee's Avatar
2003 C32 AMG
There is a possibility that the magnet and the shavings have fallen into the area in the bell housing where the torque converter sits... see if underneath you can remove the rubber plug that kind of seals that area and use a blow gun from the top of the cps hole and hope for the best... if not much comes out / no debris you're going to have to remove the transmission.. which honestly is not hard but may be challenging at home for DIY given the weight / awkward positioning.
Old Jul 16, 2015 | 10:47 AM
e55izm's Avatar
do u have or know where i can find a good instructional on removing the tranny.
Old Jul 16, 2015 | 08:05 PM
Supgee's Avatar
2003 C32 AMG
Pm me your vin and I'll give you the WIS/Factory instructions for the transmission r and r as well as refill procedure
Old Aug 3, 2015 | 02:20 PM
e55izm's Avatar
ILL TAKE A RAIN CHECK. I SENT THE CAR TO A BUDDY WITH A LIFT IN HIS GARAGE. ILL KEEP YOU POSTED I ALSO HAVE SOME GOOD PICS OF LOCATING AND REMOVING THE CPS. ILL HAVE TO POST THOSE UP.
