UGH low oil light
I just got the low engine oil of 1 QT reading on the dash and immediately went and bought oil and upon checking the oil level I find out that we don't have a dipstick. UGH!!!!
So right after buying the oil the warning light went away. So as of now I have not put any oil in the car and am doing some research as to this. Do I wait for it to come back. Need to do some more research and figure out what to do. This really sucks not having a way to check the oil level.
You should also look to see if you have any oil leaks coming from the valve covers and surrounding areas. Are you almost due for an oil change?
1. put the key in ignition position 2
2. on your screen you should have the screen where it shows your your current mileage and the second line shows you the odometer reading.
3. now all you have to press is the "UP" or the "DOWN" Arrow on the left hand side of your steering wheel where it will now check the oil.
Hope this helps
My engine does not use any engine oil in the 15K service interval. I put in 8, I take out 8. If you are burning oil something is wrong.
Put the key in the ignition and turn to position 1. Get to the screen that shows the kilometer reading, and press the cluster re-set button 3 times rapidly. (on the left side of the cluster).
It will now show you the battery voltage, use the buttons on the steering wheel and you can read out the ACTUAL oil level.. no just "ok, not ok" it will tell you an exact measurement all the way to the .1 of a liter. Your engine should hold 8.0 liters with a cold engine and all the oil in the sump. Any more, any less = bad.
Take it with a grain of salt, but I am a tech for Mercedes Benz. Now, it's not to say you don't have a faulty oil level sensor that is giving incorrect readings. I have changed out many of these sensors for that reason. The only way to be definitive on the amount of engine oil in the engine, is to purchase the dipstick. (it is a universal dipstick for every single model, it just has millimeter markings from 0 all the way up to 700. Your engine will have a specification...) (example: minimum 122mm of oil, maximum 139mm) You check with the stick and compare to see if the oil level sensor is working correctly.
BOTTOM LINE: Don't trust the dash.
