My first Mercedes - C55 AMG
Old Jul 21, 2016 | 02:07 AM
  #51
Khan 55's Avatar
2004 CLK55 AMG W209
inferior quality glass? Are the damaged fogs OEM Mercedez? If not I would suspect the heat temperature of the globe accompanied by how cold the glass would have been outside in cold weather to have "melted" of some sort. Its possible from the pictures you provided that, that is the cause of your damaged fog lamps man
Old Jul 21, 2016 | 02:10 AM
  #52
Khan 55's Avatar
2004 CLK55 AMG W209
Could you do me a favour please?
I would like for you to post a photo of the rear mounting of your fogs as well as the bumper section when the fog is removed but a front and rear view. I think my car is missing some plate or something from around my lamps according to a friend of mine.
Old Jul 21, 2016 | 07:36 AM
  #53
MrMustard's Avatar
C55 AMG
The fogs to my knowledge are OEM, however they have a stamp on the glass with the HELLA brand label so it's possible they were replaced.
And sure, I'll be replacing the fogs this weekend and I'll take photos of the procedure. I believe from factory they use a zip tie and a bolt to mount to a plate?
Old Jul 22, 2016 | 02:16 AM
  #54
Khan 55's Avatar
2004 CLK55 AMG W209
I have no idea whatsoever. All I did was order some tiny high tensile steel allen key bolts and nylon lock nuts and mounted mine again as one had fallen out during my 1000km journey. Luckily I found it in time half falling out as prior to me buying the vehicle, they battled to get a replacement for the one side. Don't know if they just didn't want to buy OEM or were trying to outsource the part elsewhere.
Old Jul 22, 2016 | 12:49 PM
  #55
edgar86's Avatar
GLK CDI 320 2009
I just replaced my cracked one ,
You pull the grill , the retainer are fragile , be carefull.
The fog light have 4 (wood type) screw one each corner , and on the bottom one there a tab that also attach to the fender .
The zip tie is holding the rubber cap for the wire to the light buld .
You can do everything from the front of the car .
Old Jul 22, 2016 | 10:44 PM
  #56
MrMustard's Avatar
C55 AMG
Good to know, did you remove the splash guards at all? Front what I read you have to lift the car or remove the wheels
I'd much rather just pull the grill!
Old Jul 23, 2016 | 05:45 AM
  #57
edgar86's Avatar
GLK CDI 320 2009
i didnt lift the car or removed the whell , you work in front of the bumper , pull the grille back , remove 4 screw , the rubber cap at the back of the foglight , remove both wire and youre done
Old Jul 23, 2016 | 01:49 PM
  #58
MrMustard's Avatar
C55 AMG
Wow that was way easier than I expected. All you need is a small flathead screwdriver to flip the little tabs up so you can pull the grille out and a T20 screw driver
Here are the photos of each side with the mesh and light removed. You can see the tabs you need to pry open - as mentioned be careful with these as they are brittle. Overall took about 10min per side.
Old Jul 26, 2016 | 02:53 AM
  #59
Khan 55's Avatar
2004 CLK55 AMG W209
Should have guessed. C55 and CLK55 aint the same. The mounting doesn't look the same either. Thanks man
Old Jul 26, 2016 | 05:06 PM
  #60
RLx02's Avatar
C55
Originally Posted by MrMustard
Here's a pic of the other side. Look how circular the crack is. Btw the crack is on the inside.. Not the outside - exactly the same shape as the side that's totally cracked
I thought the center looked like where someone smacked with with a hammer but that's actually just a logo
Ordered a set of Lamin-x covers for the new fog lights. Since their site doesn't show anything for c55 AMG I was able to determine that our fogs are 90mm circles. 3.5 inches = 88.9mm so they will be a near perfect fit
http://www.lamin-x.com/3-5-Clear-Rou...p/sb-3.5cl.htm
It's common for that to happen over the years. BTW any covers for the fog lights will eventually burn. I had something just like that for my fogs and they became yellow and brownish after a few years.
Old Oct 9, 2016 | 07:52 AM
  #61
CfideyfiveFan's Avatar
C55 AMG
Hey Im also in Maryland I have been lurking the forum for YEARS. Now I decided to make a profile, I see people are in my area MD and have the same problems....My Hella foglights did the same damn thing!! It was cold I remember than one day I dont think it was too cold I see two perfect holes........ Im in the Anne Arundale Area
Old Oct 9, 2016 | 10:16 AM
  #62
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
Anyone have a part number for these? Need just one and am trying to avoid the dealer's cost.
Old Oct 9, 2016 | 10:42 AM
  #63
MrMustard's Avatar
C55 AMG
Yea apparently a few other generations of MB have the same issue with the fogs, it comes down to thermal dynamics. Hot glass comes in contact with cold rain/water = shattered glass. And I actually grew on on kent island, right across the water from Annapolis.
As for part number, left and right are the same part number.
Hella p/n: 2308200556 or Mercedes p/n: MB2590100
EBay link: https://www.ebay.com/itm/122119436652
Old Oct 9, 2016 | 10:41 PM
  #64
cldriver's Avatar
AW '05 C55
I have a used one for sale, $30+ship. PM if interested.
Old Oct 10, 2016 | 06:17 AM
  #65
Already ordered a new Hella. Passenger side was replaced last year and driver's side looked pitted and chipped. Polishing only made it worse. So 2 brand new ones it is. Thanks though.
Old Oct 10, 2016 | 08:57 PM
  #66
C55 AMG
Nice! I havent been there yet but next summer we will probably take a boat around the bay. Nice Ride! I have a couple E55 guys around here, im more into the driving aspects rather than power power and more POWER like those guys haha
Old Oct 10, 2016 | 08:59 PM
  #67
C55 AMG
I was going to get aftermarket super bright ones but seeing how long the stock ones lasted and how short my Chinese license plate lights died, cant go wrong with stock
