C55 Headlight how to replace.
Old Dec 14, 2015 | 07:03 PM
joc's Avatar
joc
2015 E350 4 matis, 2003- 911 porsche
I have a damaged headlight that needs replacing. What is procedure? do we have remove the bumper to get to the lower bolts?
John
Old Dec 14, 2015 | 10:39 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
Yes, there is a bolt that is behind the side of the bumper (where the fender meets the bumper).
You will need to remove:
Grill
Fender liner
Bumper to fender clips
Metal bumper grills (I think, don't fully remember)
Connectors related to the fogs and corners
It isn't too terribly difficult, but that one side bolt on the headlight is what causes a lot of the extra work.
Old Dec 14, 2015 | 10:54 PM
joc's Avatar
joc
Thanks for the information
Old Dec 15, 2015 | 07:24 PM
Naugamanator's Avatar
2005 C55
This DIY might cover what you need.
https://mbworld.org/forums/c-class-w...s-removal.html
Old Dec 15, 2015 | 08:07 PM
joc's Avatar
joc
Great information thanks for the link. Looks to be fairly easy.
Old Dec 16, 2015 | 11:25 AM
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
Don't need to fully remove the bumper. Just undo the bolts and pull the bumper out a little bit, then unbolt the headlight and pull out.
Only bolts that need to be undone are the wheel fender liner behind headlight you want to remove, bracket the connects bumper to front quarter panel, and the two bolts behind the grill which are accessed from engine bay. Once you get those off you can pull the bumper forward enough to give you room to unbolt the headlight (3 bolts, 1 on each side and one on top) and pull it out. Pretty easy actually once you've done it once or twice. the bracket uses a T20 screw I believe FYI. Rest are like 10mm bolts or so.
Old Dec 16, 2015 | 01:05 PM
joc's Avatar
joc
Thanks everybody for the repose, I have it now, will do it this weekend
