WIDEBAND AFR&BOOST GAUGE INSTALL
A few unimportant points. Mounting the AFR probe where you did is a bit too far from the OEM O2 sensor location. You are probably off by 0.1-0.2 AFR, not a big deal. The bigger issue is that if anything goes wrong in one of the banks, because you are doing an average AFR, you will not know which bank. But at least you will know that something is wrong.
For the Boost, a better location would have been the lower Y pipe. That is closer to the OEM MAP sensor. But again, what you did is much, much better that not monitoring.
I had to cut into that grill and secure it from the underside.
wide band fail safe so you can set alarms or flashing lights on the dash or hook up a buzzer if at anytime the car over boost of fuel runs lean at high speed you can be alerted and let off the throttle.
