CLK63 030 SLK brake upgrade
Old Mar 7, 2016 | 01:37 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
I wont have to worry about brake fade when iam tracking it.
This is almost completely dependent on the pads and fluid you are using.
Old Mar 7, 2016 | 06:29 PM
Brezza AMG's Avatar
2005 C55 AMG
brake fade comes from either:
- boiled brake fluid
- cooked pads
I'm no expert, but I've had a fair bit of experience over the years. and have tried many different combos and had different track experience.
what I've learnt is:
- Pads are most important - get pads that suit the temp range that you'll be using them
- for Street just get a moderate pad, you'll rarely need a track capable pad. and the trade off at decreased cold braking isn't worth it. plus track pads tend to chew rotors
- if you track your car, just get a set of dedicated track pads, they'll last ages because you'll only put them in for track days
- get a brake fluid that has the highest boiling point, don't break the bank too much. but you'll feel the difference with a good quality fluid and properly flush out your old fluid. if you're changing the type of fluid (buy 2 bottles) fully flush a bottle of fluid through and use the second one to top up.
- rotors make hardly any difference to brake performance compared to the 2 points above. buy cheap rotors, not rubbish ones. but money is better spend on pads and fluid rather than fancy rotors. if you're running track pads rotors will become a consumable so its better if they're cheap. std rotor vs slotted vs cross drilled vs 2 piece, its all a much of a muchness. just ensure they're skimmed and aren't warped and you're good to go.
I've found:
std rotors to be okay
slotted are a minimal improvement (will produce more brake dust)
cross drilled - I've never had any crack, I think this is more problematic when drag racing and the rotor goes from cold to hot very quickly
2 piece, they look cool, but are $$$
Old Mar 7, 2016 | 08:07 PM
Sickooli's Avatar
E250 cdi
+1 brezza
Old Mar 8, 2016 | 10:41 AM
Smokey31's Avatar
C55 AMG
The rear SLK55 030 brakes are the same as the rear CLk63 aren't they?
Old Mar 8, 2016 | 11:58 AM
Sickooli's Avatar
E250 cdi
yes they are the same
Old Mar 9, 2016 | 09:51 AM
dsp_tdi's Avatar
2005 C55
For me, I just updated the rear with 4 piston and the brake balancement are very good. The car is more balance on high speed breaking and sit better. I have ebc yellow brake pads on 4 corner, ATE racing fluid and braided hoses.
6 piston are look very better, but 4 piston with race pads and good wider tires are the best way to go for track.
My father have a SLK 55 with 6 Piston and normal tire 225, seriously this brake setup is overkill the tires But for the look ... I love them.
Old Mar 25, 2016 | 04:07 PM
  #32
Smokey31's Avatar
C55 AMG
Got the CLK63 brakes on the front today.....and the wheels don't clear the calipers. I have a tiny bit that hits the inside of the wheel, but strangely I can turn the wheel 3/4 of a turn with no clearance issue. This is the same for both.
So my wheels aren't round or I have a problem with my hubs?
This is on stock C55 rims.....
Iam gutted.
Old Mar 25, 2016 | 04:20 PM
  #33
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
What is the part number on your front rims?
Old Mar 25, 2016 | 06:37 PM
  #34
Smokey31's Avatar
C55 AMG
No idea, there stock rims.
Old Mar 26, 2016 | 07:48 AM
  #35
Smokey31's Avatar
C55 AMG
Lenin ive just noticed you have the same brakes.
On my pads, I don't seem to have a hole in the pads to put the wear sensor in. That's on front and rear....
Old Mar 26, 2016 | 10:41 AM
  #36
Lenin's Avatar
Iam gutted.
just to be clear. When you say "I can turn the wheel 3/4 of a turn" you mean spin the wheel? If that is the case, then it does sound like something is wrong with the geometry of your front end. Please confirm that you are not using any spacer and that your rims are perfectly flush on the hub. Make sure that to crap got stuck to the wheel and the hub. Very strange that both wheels exhibit this behavior.
Old Mar 26, 2016 | 10:53 AM
  #37
cm60k's Avatar
+1 with Lenin,
Also, try to shoot some pics. of your fitment, and Rims from inside, it will helps a lot to narrow the issue..!!
ZAYED,,
Old Mar 26, 2016 | 02:03 PM
  #38
Smokey31's Avatar
C55 AMG
Yep, that's correct, I can spin the wheel 3/4. The wheel, seems to touch the caliper where it says AMG, and Brembo on it.
Not using any spacer.....
I haven't completely torqued up the wheel bolts, but they are pretty tight with the wrench from boot, I was expecting to remove the wheels again, and obviously I cant drive it at the moment.
Im stumped because other people have fitted this and not had issues.
I will have a better look tomorrow, and try and take some pics from the back.
Thanks guys.
Old Mar 29, 2016 | 11:17 PM
  #39
Brezza AMG's Avatar
2005 C55 AMG
Drill a hole into it, I had the same thing.
drilled a hole and put the sensor in, I drove for a while without it but was sick of seeing the warning come up on the dash all the time.
Old Mar 31, 2016 | 09:02 AM
  #40
Khan 55's Avatar
2004 CLK55 AMG W209
These front pads don't have a hole but rather a slot like the C63 pads do. My front right side wheel has one sensor mounting with hardware and it takes a horse shoe like looking or triangle like type of sensor. My rear however uses a two wire single probe like sensor. Lucky my old one was reusable even though my brakes were shot but it hadn't shaved through the plastic on the sensor as yet so I reused it without any codes or warning lamps.
Old Apr 2, 2016 | 02:26 PM
  #41
Smokey31's Avatar
C55 AMG
Yeah, I got MB to send me the correct sensor for the fronts, all sorted now.
Ive changed the wheels to some CLK 63 18's, though they have been badly redfurbed and in black so I need to re-do them in titanium silver.
Old Apr 2, 2016 | 06:47 PM
  #42
cm60k's Avatar
Titanium silver is great choice, depend of your C55 color..
ZAYED,,
Old Apr 3, 2016 | 08:06 AM
  #43
Smokey31's Avatar
C55 AMG
Sorry, I meant Titanium Grey.
My C55 is Odsidian Black.
Old Apr 3, 2016 | 12:01 PM
  #44
Smokey31's Avatar
C55 AMG
Heres what it looks like at the mo
Old Apr 3, 2016 | 05:42 PM
  #45
cm60k's Avatar
Looooks Nice,
I think if you paint the Rims like the body Black, with Red or Yellow calipers, it will become an amazing "MONSTER"....
ZAYED,,
Old Apr 4, 2016 | 09:22 AM
  #46
Morphh's Avatar
C32 amg
Originally Posted by cm60k
Looooks Nice,
ZAYED,,
How do they feel the brakes now much better?
Old Apr 4, 2016 | 02:09 PM
  #47
Smokey31's Avatar
C55 AMG
Not going to paint brand new calipers, very happy with the look in silver.
Like said, just going to sort the wheels out.
Yeah, they are still bedding in 100%, but they feel stronger for sure.
Old Apr 4, 2016 | 02:47 PM
  #48
WaveyKat's Avatar
Something Slow
looks good :-)
