Front 6-pot calipers from SLK55AMG. Can I use 345mm brakes?
No need, the brake master cylinder is fine, these brakes are fitted on the SLK55 and W209 CLK afterall.
Id imagine it would struggle with the 8 pots off the 55K engines, but those brakes don't fit anyways.
i think 400E brakes will fit to the 190E spindles, but it may need little bit to balanced the Rotor in the center of the caliper, not sure about that..!
simple touch..
,,ZAYED,,
and it will be approx. (5.5mm) gap in the Rotor Ring (that pad will NOT surface it),,
cause the center dia. of "C32/C55" Rotor Hat is (226.5mm), while center dia. of "Clk55/Slk55" Rotor Hat is (218mm)..!
,,ZAYED,,
