Repair shop is $180 an hour (brakes, flex disc, and thrust arms et al.)
Old Jul 26, 2016 | 12:29 PM
DriveMyC55's Avatar
C55 AMG
So I have a 2006 C55 AMG and am headed to Korea (think you Army). I want my wife to be able to drive it while I'm gone (some/not a lot) but want to insure everything is taken care of before hand. I want to replace these parts, just need suggestions of whats better for the money (bang for the buck)
Brakes and Rotors- Akebono (EUR847 front EUR603 rear) pads with zimmermann cross drilled rotors (400362820 front) I need suggestions for the rear (?)
Thrust Arm Bushings (I'm thinking Lemfoerder)
Control Arm Bushings (I'm thinking Lemfoerder)
Flex Disc I have no idea (help) I'm thinking Lemfoerder
I just replaced both engine mounts and trans mount with Lemfoerder $133 parts and $260 for labor-(best deal i found) http://www.importpartsdepot.com/Merc...cs_p_1532.html
Additionally I need to replace the REAR MAIN SEAL of the CRANKCASE, what would labor cost on this, as the person that fixed the mounts quoted me $595 to do this. Sounds like a good deal to me but I'm simply a guy that changes spark plugs, air filters, and oil.
Help...
Like I said the Mercedes shop is around $180 an hour here in San Antonio and I just simply can't afford to get everything fixed at their prices. Also if something is easy to do, let me know. I'm sure I'll take a look at it doing it myself.
Thanks in advance
Old Jul 26, 2016 | 04:11 PM
93Corrado's Avatar
'05 C230 SS, '94 E420 (RIP), '05 C55
Brakes and rotors are straightforward. Do it yourself and save the cash. There are numerous DIY's to show you how to do it, even on Youtube.
I just replaced my brakes with the Akebono Euro Ceramic pads and Zimmerman Coat-Z rotors.
The bushings will require a press so best to let a shop do it.
Only Lemfoerder or Mercedes for the Flex Disc. That too is not a difficult job if you want to save the cash.
Rear Main Seal is labor intensive. $595 seems really low.
$180/HR sounds like a really high rate for an independent shop.
Google turned up 7 or 8 Mercedes shops in the San Antonio area. Shop around.
Old Jul 26, 2016 | 04:54 PM
DriveMyC55's Avatar
C55 AMG
Thanks for the in dept reply. Have you had any noise from the brakes and how is their over all performance?
The videos are good and yeah I'll probably knock those two things out.
$180 an hour is the price that Mercedes gave me. There are a few other shops around that will do $120 an hour. Still rates like this make me want to go to school to be a mechanic.
The $595 is a Korean guy that has done work on my vehicle already, as long as it's nuts, bolts, and typical work that all cars have; I trust him.
I wonder if he would do the brake job cheaper since I'll probably get him to do the bushings and arms?
Old Jul 26, 2016 | 09:41 PM
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
I have those exact Zimmerman's and hate them. My butt-dyno felt no stopping gains but I definitely felt the grinding-like pedal feel.
Had my flex disc done and car felt noticeably smoother. 16 new plugs helped too. And get that $595. rear main seal price in writing because that's less than 1/2 price.
Old Jul 27, 2016 | 06:23 AM
Khan 55's Avatar
2004 CLK55 AMG W209
That 2nd video on a flex disc change aint gona cut it for a C55. That car in the video is a Merc yeah but it aint as straight forward as that guy did it. You will battle a bit more at the rear than he did on our cars but as for the front, that's another story on its own.
The brakes is an easy job. Just ensure you change brake fluid when you doing this job.
As mentioned above, that rear main seal is a PITA and at that cost, get it in writing and a descriptive detail to next to that for the labour that will be carried out. I thought of it myself as mine has a leak and the main seal from agents cost roughly $40 in my country. But now for me to do the job myself won't be straight forward as I thought it might be. Well if the guy is at it, he might do a gearbox oil and filter service whilst at it if you haven't done it and then do the seal as well as the flex disc and probably get him to change the carrier and propshaft bearing. Atleast then you know you good to go for another 150 000km or more depends on your driving. NB exhaust have to be removed out of the way for the propshaft to come out as well as heat shields and covers and O2 sensors being removed.
Old Jul 27, 2016 | 09:59 AM
RLx02's Avatar
C55
If you're in the army, shouldn't your base have a resource center with a free garage with access to a lift and tools? I remember every base I was stationed at had a garage with a lift tool rentals for free; used to work on my turbo eclipse there.
Old Jul 27, 2016 | 02:18 PM
DriveMyC55's Avatar
C55 AMG
We do have two auto hobby shops close by but there is none on Fort Sam. I will go and use their stuff, so it makes it easier on the labor part.
I'm more interested in the parts and whats best for the money that is going to be spent. I can get Zimmermann Rotors (Z coated) for about $120 a piece... should I save some money and just do the EBC?
I'm just looking for the best part suggestions I can get.
Old Jul 27, 2016 | 02:24 PM
DriveMyC55's Avatar
C55 AMG
Hey, the $595 is in writing and I trust the guy doing it. So your Zimmermann rotors gave you grief, what kind of pads did you use with them? So if it's not zimmermann, than what do you suggest?
I did the plugs probably 5000 miles ago, fair improvement in power after doing that. Just need to get the rest of this stuff under control.
Old Jul 27, 2016 | 02:44 PM
93Corrado's Avatar
I've been using Zimmerman rotors for years and never had any issues with them. They work well on my C55 with the Akebono Euro pads. AutohausAZ sells the Zimmerman Coat-Z's for $95.41 each with free shipping.
Old Jul 27, 2016 | 03:20 PM
RLx02's Avatar
C55
I used OE replacement rotors for 80/piece online and akebono ceramics (40?) (dust free) when I did my fronts...was around a total of 200 for the fronts. They are just as good as stock, if not better. Especially now that they're dust free.
Old Jul 28, 2016 | 03:54 PM
DriveMyC55's Avatar
C55 AMG
Do you have a link for the pads at $40? I"ve found them on Amazon for $55 and a few other sites for $80. If so, can you post?
Old Dec 27, 2023 | 01:30 AM
Drive9's Avatar
2005 C55 AMG
Smile myc55too
hey @DriveMyC55 Long shot! haha . ..how happy were you with your buddy replacing your rear main seal? My C55 needs it bad, and guibos, transmission oil and filter, and carrier/prop shaft bearing.
Old Aug 18, 2024 | 12:53 PM
Faast's Avatar
'91 964 Turbo, '02 E55's & '14 E63s-w
That was back in 2016, everything has gone up like 500% with this inflation crap LOL
