Wobble at highway speeds
Old Aug 12, 2016 | 01:18 PM
Morphh's Avatar
C32 amg
Having issue with a bit of vibration at highway speeds 65-75mph, new Toyo tires, new OEM rotors, akebono pads, front tires have been re balanced, 4 wheel alignment done. Does not shack when hitting brakes, drivers tie rod end new, passenger side upper control has small crack in bushing.
Any help would be appreciated. Thanks
Old Aug 12, 2016 | 03:30 PM
MrMustard's Avatar
C55 AMG
Spacers? I had a vibration at the same speed and it turned out my spacers in the back were causing it. That and I had cupped front tires.
Replaced front tires and shaking mostly went away, but once I took the spacers off it all went away completely. Never going to put them back on.
They were 5mm btw
Shaking from the steering wheel = front wheels
Shaking from the seat/floor = rear wheels
Old Aug 12, 2016 | 04:38 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
could be control arm bushings too.
Old Aug 12, 2016 | 08:11 PM
cm60k's Avatar
^^Agree with all stated above^^,
also check the drive shaft/drive shaft center bearing..
,,ZAYED,,
Old Aug 12, 2016 | 09:41 PM
Morphh's Avatar
C32 amg
No spacers on car, going to replace upper control arm passenger side this weekend. Will check drive shaft flex discs and bearing car has 112,000 Kms
Took down 2015 rs5 couple days ago lol
Old Aug 13, 2016 | 10:42 AM
Morphh's Avatar
C32 amg
I think I figured it out, brought my car in to rebalance tires again, and tech good friend of mine says drivers side wheel has a high spot in it, he says its common on Mercedes factory wheels. Fix 60.00 Canadian, will keep everyone in the loop if it fixes it
Old Aug 13, 2016 | 11:24 AM
cm60k's Avatar
Glad you solve it, Thankss for sharing..
,,ZAYED,,
Old Aug 13, 2016 | 07:52 PM
Morphh's Avatar
C32 amg
I was going to buy the racing brake rotors, but I saw a few issues with them on YouTube, they breaking apart or seperating, anyone know where else to get light weight rotors from?
