Location to insert smoke into engine for smoke test
Old Oct 2, 2016 | 06:44 PM
c32jet's Avatar
I have a bit of a stumble at stop lights... the engine bobbles a bit and I believe it is a vacuum leak some where.
I built a smoke test machine and am not sure where to connect it to the C32 2002 engine.
Any recommendations on which tube or connector where I can input smoke into the engine looking for the vacuum leak?
Old Oct 3, 2016 | 09:34 AM
Morphh's Avatar
C32 amg
[QUOTE=c32jet;6931327]I have a bit of a stumble at stop lights... the engine bobbles a bit and I believe it is a vacuum leak some where.
Thanks[/QUOT
Im thinking vacuum lines,
Old Oct 3, 2016 | 10:55 AM
c32jet's Avatar
[QUOTE=Morphh;6931779]
Thanks[/QUOT
Yes, but where? I tried pulling a few what I believe to be vacuum lines and hooked up a hose and tried to blow smoke in from a cigar... I couldn't blow 'any' air in. Either the thing is super air tight or I am not doing it right, hence the request to the experts on the forum.
I will find a map of the vacuum lines... and keep testing trial and error.
I am weekend mechanic (if that even) was hoping someone could point me to a specific location. Thanks.
Old Oct 4, 2016 | 12:16 AM
Morphh's Avatar
C32 amg
[QUOTE=c32jet;6931861]
Throwing any codes ?
Old Oct 4, 2016 | 12:17 AM
knowbenz's Avatar
Benz
With a real smoke machine I always pump it in the purge line, take it off purge valve and pump smoke in there. Not sure if a cigar will work though
Old Oct 4, 2016 | 06:49 AM
c32jet's Avatar
Smoke into purge value idea for smoke test - thx
<<With a real smoke machine I always pump it in the purge line, take it off purge valve and pump smoke in there. Not sure if a cigar will work though>>
Not throwing any codes..
Thanks, understood.. I have a machine to do it now... the cigar was a bust (laughable now that I think about it - watching too many videos on youtube on how to solve the problem).
Thanks for the purge valve idea, I will give that a try.
Old Oct 4, 2016 | 03:52 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
check your engine mounts...if put put the car in neutral at a complete stop if the engine stops shaking thats a good sign of a bad engine mount
also if you have someone look at the engine bay with hood open if the engine moves from left to right when accelerating that is another sign of a failed mount
