Replacement Key Fob Case
My key works fine, its just that the case is cracking on the un lock section of the key. Can I just replace the case (I see lots of them on Ebay) and transfer the internals and have it still work properly?
Received 4,417 Likes
'71 Pinto
Certainly, one of several videos…
gofisch (01-21-2017)
Ya it's expensive cuz it's rare. You'll see nearly no one with them besides me and a handful of others.
I was going to get one of the chrome ones but it didn't appear the internals would fit. Can you post a pic of the one you bought?
This style key with the triangle panic button does not come apart like the previous keys. What you bought is worthless to anyone except whoever owns the car it belongs to.
Ok, and the internals from the old black plastic style do not just go into the chrome key with the round panic button. The chip has to be removed from the circuit board of the old one and put onto the chrome key circuit board for it to work.
Correct again. Thank you for all of your help. With your snarky, passive-aggressive retorts, no doubt you'll make a great wife someday.
Interesting. You were the one sounding unsure if it would work or not. I'm just saying how it works from experience. Not sure what you take as a passive aggressive retort but I'm not trying to come across that way.
Well, I for one am glad for the back and forth. Otherwise I wouldn't have learned about the chip thing and the triangle and circular panic button. I would have ended up either buying the wrong one or the right one and not know to transfer the chip. Speaking of this chip, does one just remove it by hand and replace into the new fob? ; )
All things that have been covered extensively with DIY and pictures in the forum. Please search
And to Rocman, posting that the fob I mistakenly linked to is "worthless to anyone except who the car belongs to" is simply an *******ish reply. If that isn't obvious to you, get help for those around you.
While I agree the redundant threads get old fast, after 11-12 years, hasn't just about everything been covered at some point and time by now? Should we just leave this sub-forum open for searching only from here on out?
Ah, OK then. Your reply makes more sense knowing that. I almost bought two of the wrong ones before doing some searching first. No worries then.
Well, the plot just thickened. eBay auction showed a lot of roughly 12 round panic button fob's so I bought two. Both showed up with triangular panic buttons. Am I correct, along with Rocman, that these are useless to me?
