Shaking over 70mph
CLK63 Black Series
Shaking over 70mph
my cousin took the C32 to Washington D.C... he is on his way there right now, he just called and told me he is getting alot of shaking over 65mph.. what could be the reason? i told him to do the basics, check the lug nuts, make sure the wheels are on good.. but is it something urgent that he may have to put the car on the lift he doesn't know **** about cars so he doesn't know what to even look for.
CLK63 Black Series
Originally posted by MB///HRV
bent rim & or missing wheel wight....
CLK63 Black Series
ok talk to a friend with 540R wheels and he said it's the design of the wheels.. since it's reversed lip, water tends to collect in it (it's raining heavy in DC) and that throws off the balance on the wheel. I called the shop that installed the suspension and they confirmed it as well. Not much can be done but complain to HRE.
pretty crappy for such a $$$$ wheel.
You may check (if you have them) the spacers. Spacers not installed 100% properly will cause shaking and vibration. Check tire balance and last, alignment.
CLK63 Black Series
CLK63 Black Series
pretty crappy for such a $$$$ wheel..
I hit a pothole and ever since I have some vibrations around 60 mph. The rim is not bent nor the tire buldging. I haven't checked the wheel weight but I think my alignment is screwed. Funny thing is that when I get up to over70, my car is smooth as silk. You think that exuse will fly when I get pulled over
On another note, why are you letting your cousin drive your AMG, especially one that doesn't know jack about cars.
CLK63 Black Series
'05 A4 1.8TQM6
Originally posted by AMG BRED
when i called the shop about the situation.. he laughed and said "if i recall correctly you have 546Rs on your car... ironic how people pay 2000.00 for wheels don't have a single thing to complain about but those who pay 6000 for custom wheels have ****ty designs"
The rim could always be bent on the inside of the wheel, so unless you take the wheel off, you may never know. It also doesnt take much of a bend to throw off the balance of the wheel. Certain MPH will cause the resonance, while other speeds my improve or make it worse
1996 C36 AMG, 1995 Volvo 850 Turbowagon
that is always a sign of imbalance. usually not below 55 and not above 70.... shakes just in between there...
have ur rim checked for bends on a machine, not visually... a bent rim can't be balanced no matter how hard u try... and after hearing u say u hit a pothole, it's possible it may have damaged the rim.. the less costly thing would be some wheel weights had been jarred loose, that's an easy fix. any good hunter technician should be able to find out in a sec or two if ur rim is bent or not...
improper alignment will not cause shaking...just lousy tire wear...which can lead to weird tread patterns after continual use like that...then maybe the tire can develop some weird stuff...but then, it usually develops patterns that are parallel with the tire rotation...so it'd be hard to notice any shaking anyway...
CLK63 Black Series
Re: saw amg bred's car
Originally posted by moa4r
I saw your (cousin?) driving around tysons last night in your c32
your car looks really hot in real life
S4
Re: Re: saw amg bred's car
thank you. now was he bahaving himself? how many people did he have in the car? how fast was he going?
j/k, there were like two other people in the car i think, but it was hard to see cuz of the tints
CLK63 Black Series
Re: Re: Re: saw amg bred's car
:p he was driving like a maniac now that you mention it
S4
Re: Re: Re: Re: saw amg bred's car
I knew it!! Time to do burn outs in his car
CLK63 Black Series
Re: Re: Re: Re: Re: saw amg bred's car
in all honesty, he was driving totally normal, you've got nothing to worry about, I was only messing w/you :p :p, great car, though, I thought it was an e55 when I first saw it fom far away, then when I got closer, I realized it was your "AMG BRED" c32---
