Supercharger problem
I just reemplace the intercooler supercharger, i fix the leak, everething good not leak more, but now after 20 minutes to run fast, the supercharger shout down, , and on , shount down , i conect the obd2 Edu, and show the iat sensor , i change for new one run better , but today again the problem with the charger iré sometimes
please what problem you think its
Can you read the IAT from the OBD2 scan tool? If you can - what is the temperature when driving? I think it shuts down around 180 F, so it needs to be lower.
Check the intercooler pump (RF Fender well) and see if it is working. If it does not pump coolant, the system gets too hot and shuts down.
best thing you can can do is put a couple of wire splicers into the positive and negative on your own heat exchanger water pump and go straight to the battery. See if it runs. If it does let it run for a bit to see if it cuts out after it gets hit. If it dies replace your water pump with the one above I linked you to. If it doesn't die. Start looking at fuses and see if you have one that could be blown
