HELP! I need a new key
Old May 12, 2017 | 09:55 PM
AtlasMG's Avatar
2006 Mercedes-benz C55 AMG
I have a 2006 mercedes c55 amg and the plastic key the unlock button broke off and i need a new key and i would really like the chrome one and when i look up on ebay or amazon they show up as they fit so can i just buy the chrome one and put the bored in or will i need to do something if anyone has a link to a chrome key that will work please send.
Old May 12, 2017 | 11:06 PM
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
The dealers say only they can do it due to matching the VIN to the new key, etc., etc.. Others have said that's bull and the proper key from Amazon​ or eBay will work but just needs programmed correctly.
I guess I'm not helpful and want to know as well.
Old May 13, 2017 | 02:40 AM
Gramma_Benz's Avatar
2002 C32, 2012 S550
So the insides are OK and you just need the housing?
I bought a housing on eBay and swapped out the internals. There's a vid on youtube that shows how to do it
Old May 13, 2017 | 11:03 AM
AtlasMG's Avatar
Ya Thats what i was hearing i called the dealer they said ill be 280 to 380 and im not going to put that much money into a chrome key.
Old May 13, 2017 | 11:04 AM
AtlasMG's Avatar
Oh really there was a post they said you need to do something to your bored can you send me the link to youtube and a link the a key that you got or think will work?
Old May 13, 2017 | 04:18 PM
MacVidMB-V8's Avatar
W209, W124
Here is a good thread with all the info you need:
http://www.benzworld.org/forums/c209...-retrofit.html
Hopefully you don't get bored reading about the circuit boards.
Old May 14, 2017 | 02:18 PM
Jon@MBPartsFactory.com's Avatar
Former Vendor of MBWorld
Mercedes
Hello,
Dealers do not have the ability to program these as it's done by the factory so you can't buy one and get them to program it. The black key internals do not fit the chrome key so the best bet would be to replace the housing with the same one or buy a new key. Unless you are good with soldering tiny circuit boards
Old May 15, 2017 | 02:40 PM
2002 C32, 2012 S550
This is the one I bought:
http://www.ebay.com/itm/2-Smart-Remote-Car-Key-Fob-Smart-Shell-Case-Battery-Clip-and-Insert-Replacement-/111828388759?hash=item1a097dcb97:g:ZY8AAOSwKtVWuNT z&vxp=mtr
Old May 15, 2017 | 10:26 PM
AtlasMG's Avatar
Hey one more thing If you need to change the chips then why dose it say it fits on ebay i look up 2006 mercedes c55 amg keys and they come up and say they only fit on c55 amg's are they trying to scam or did they mod the key all ready? and the keys go for like 15 to 45.
Old May 16, 2017 | 02:35 PM
ghiaguy's Avatar
C55 AMG, 300D-T & Karmann Ghia
Anyone know if the metal insert key needs to be cut to fit in the fob? The L shaped one that slides into the fob and has a keyring. I lost my keys and thankfully had the Merc fob off at the time. I've been trying to get another metal key so that I can attach the fob to my new keychain...
Old May 16, 2017 | 02:41 PM
Mercedes
Hello,
The metal key does not need to be cut to fit, but it does need to the correct blade key. If you don't have a cut blade key to your vehicle you can't lock your trunk in valet mode lock your glove box or enter the vehicle in the event your battery dies in the key. So I would recommend getting the proper blade for your key. One thing to keep in mind is that the non-cut keys could be after-market and like anything after-market there is no guarantee of proper fitment.
Black key uses 203-766-01-06
chrome key with oval panic button uses 203-766-50-06
chrome key with triangle panic button uses 212-760-19-06
Old May 16, 2017 | 02:46 PM
ghiaguy's Avatar
Wicked!! Thanks a lot Jon. I appreciate the parts numbers too, that is likely where I went wrong. I got one for the chrome key, but it doesn't fit so I must not have taken my triangle panic button into account.
Old May 16, 2017 | 04:06 PM
W209, W124
You can order the metal blade already cut from the dealer using your VIN. When I swapped my black keys into Chrome boards I had to get new metal keys. I seem to recall they charged like $60/each but they were pre-cut and slid right into the key fobs.
AtlasMG, if you read the thread I linked you'll understand this all much better.
