SLK32 AMG M112 2004
Old Dec 6, 2017 | 08:11 AM
Luzanne's Avatar
SLK32 AMG 2004
SLK32 AMG M112 2004
Hi, anyone got the con rod dimensions and block dimensions for a SLK32 AMG 2004 R170 (engine 112.96)
Old Dec 7, 2017 | 04:42 PM
feets's Avatar
2006 C55
I do not have those number but can you tell us what you have in mind?
Old Dec 8, 2017 | 12:08 AM
Luzanne's Avatar
SLK32 AMG 2004
Hi, the engine block needs to be machined & re-sleeved. Existing conrods have been modified (by previous owner), basically stuffed up everything. Bought new set of original pistons, thus need original specs for block machining and have rods custom made to original specs.
Old Dec 8, 2017 | 05:41 PM
feets's Avatar
2006 C55
Mercedes blocks are NOT sleeved. The bores are aluminum and have been treated for durability. Do not hone or bore a Mercedes aluminum block unless you have the proper equipment to provide the correct finish.
You'd likely be money ahead to grab a used engine and stuff it in there.
