C55 square stance
C55 square stance
Looking to run lighter weight wheels and square stance so I can rotate the wheels as well as ditch the understeer. Has anybody done this? Is it true that I will not be able to run the same offset on the rear as on the front?
The offset front to back is different and you can not put a 245 up front with out a lot of work so, you can only reduce the rear width to match the tires.
245s up front on stock wheels going on 8 years now. They rub the front of the fender liners at full-lock, but otherwise, have zero issues. I'm dropping down to a 235 for better turn-in though. The 245s feel a bit numb and did nothing for understeer, so smaller it shall be.
There is one guy who auto cross his car has 275 all four corners but a shil load of work and money.
I track my car and run 18x9x235 r888 up front and 18x10x255 super sport out back for track.
Correct, but like I posted, it seemed to do absolutely nothing for understeer and made turn-in sluggish. 245s also didn't look any meatier than the 235s compared to squeezing 265s out back, which really fattens the rear end up.
What's your tire height, 35 or 40?. I currently have 255/35/18 Firestone Firehawk Indy 500 in the rear, and since the firehawks run narrower, I can run a 265 easily but only another firehawk. I previously had pzero 255/35/18 in the rear, and they stuck out over the lip of the rim. My firehawks almost look stretched at 265. I'm thinking about running 245 indy 500 in the front and maybe 255 with some fender rolling. My guess is that 245 indy 500 in the front will be like putting a 235 pzero in the front. Is it really difficult to put a 255 in the front? Also going to try 275/35/18 firehawks in the rear soon. All on stock rims
I tried 265/30 Super Sports out back and they rubbed on one side on compression. Most everyone else here says they've had no issues with 265/30s, but I'd need a bit of rolling or trimming and don't care enough to do it, so 255/30s for me.
slize (03-15-2018)
I ran 245/40s up front and wasn't thrilled. The 235/40s I have now just seem a bit quicker and don't understeer any more than the 245/40s.
I'm about to order new tires, 235/40/18 in the front, and 265/35/18 for the rear. i'm getting the Falken Azenis RT615K+. I've already tried the firestone indy 500's, and determined they're the best bang for buck. Decided to try something new. Do you think running 265/35/18 will have enough clearance height wise? Haven't lowered the car at all.
I do miss my 265/30s though!! they made the rear meaty AF! the 255s still look meaty but can def see the stretch
I was mainly concerned about running the same rim offset front and rear. Seems like a lot of MBs can't wear the same rim front and rear. I'm not sure a wider tire would benefit the C55 as much as a softer compound would, I have a 255 rear right now, I'll be going back to a 245 rear, I doubt it will make a performance difference.
ae86 and w203 wagon
maybe an e55 front wheel?(guys know specs?) you need the wider wheel to support the wider tires or it does nearly nothing, there are MANY videos/posts about this from suspension sites. Id like a square just for the sake of being able to rotate tires properly and wear. You guys are saying the one size difference isnt enough to feel, well of course not! needs to be at least a 1" wider wheel AND tire.
Grip is largely a product of tire compound rather than the size of the contact patch. Most cars are much better off going to a softer compound than a wider tire size. Wider tire/rim also brings with it more weight, negating much of the benefit of going to a wider tire. I'd much rather run 225 all around with a very aggressive tire compound than 245 front and 265 rear.
Doing both 235 and soft compound will benefit the most
