Lowered W203...where to get alignment done?
Would a dealer be able to align it properly considering its lowered? Its not slammed or anything but definitely not stock height.
I am located in Sacramento, CA. If one of you guys live here and know a place please share.
The rear has toe only too, but you need special bushings to adjust camber. They can be found on eBay and other places.
If you just need toe set, any shop can do it.
Why would I need two sets of alignment bolts for front? Unless you meant one for front and one for the rear?
Each bolt is good for about 0.42 degrees camber, but they also affect caster.
Here's good info on what,where, and why...
https://mbworld.org/forums/c-class-w...ml#post5078140
http://www.benzworld.org/forums/w211...ml#post4448248
