what tire do you guys run?
Old May 10, 2018 | 02:00 PM
PelicanParts.com's Avatar
SPONSOR
Originally Posted by PJmak
Ordered a pair of Hankook V12 Evo2.
Man I need to change my wheel setup. The 19s in this size are expensive.
Nice, V12 Evo 2's are a solid tire for everyday use and some spirited driving. I think they're pretty quiet too, and I've been running them on one of my cars since the original V12 Evo years back.
19's are expensive in general, compared with 18" and 20" wheels. Just an odd size that not many cars run, so we pay for it, unfortunately.
Old May 10, 2018 | 02:30 PM
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
I agree. IMO, the Evos are a better day to day tire than my Michelin SSs, but don't have quite the dry grip.
Old May 17, 2018 | 11:07 AM
PJmak's Avatar
So I got my tires. brand new but theres a year stamped on it(not sure this is a year but it says 2012)
Should I be concerned??
What number format is the date in usually on the tire. This has
some sort of symbol than number 2012 right after it. This might not be the rear, can someone who has the same tire confirm before I go asking for a replacement.
Old May 17, 2018 | 02:16 PM
PJmak's Avatar
Nvm its a 2017 tire
Old May 17, 2018 | 03:54 PM
PJmak's Avatar
So far first drive the car feels good, smooth and grippy.
I could probably use an alignment
Old May 18, 2018 | 01:29 PM
greekspec2's Avatar
2005 C55
I had these on my c43, it felt like a go cart.
As far as Michelin PS4....Id want something cheaper on a lowered car coz they probably wonr last long. Id hate to burn through a set of thousand dollar tires in a year
those were brand new and if you never flipped them then your wasting your money, the car was just aligned when I gave it to you. Did you ever take care of the rear diff mounts?
Old May 18, 2018 | 01:33 PM
  #32
PJmak's Avatar
Na I guess I forgot about that. Ill have a look at it.
Had the rear main done and the flex disk checked(looks good so dont need to do it yet). Just did the rear tires but other than that the car has been really good to me.
Getting a SUV soon so Ill be driving it even less.
Old May 18, 2018 | 01:37 PM
  #33
greekspec2's Avatar
2005 C55
the rear flex disk were new already changed I left you the front disk to replace....that high speed vibration and twitchy rear is from the rear diff mount blown change it asap its a safety issue ....the rear tranny mount has been done
Old May 18, 2018 | 01:43 PM
  #34
PJmak's Avatar
Thanks for the heads up man Ill get on it asap. I did notice vibration on the highway but was gonna check the alignment sheet you left to see when that was done and was gonna do alignment after new rear tires.
I thought the guy checked both flex discs when he did my rear main but he might have only checked the rear.
Been so busy, im moving and the baby is getting bigger. Hard to find time to even do an oil change in the last few months lol.
Old May 18, 2018 | 01:45 PM
  #35
greekspec2's Avatar
2005 C55
this car was aligned by Fairfield MB a few months before I handed over the keys and before that by myself at Audi.....the front control arm bushings have been done and the rears also get that diff done I used those tires for years and were factory installed on the Performance Pack C55 and SLK55 Black Series I got 25k-30k easy
Old May 18, 2018 | 01:59 PM
  #36
PJmak's Avatar
I need to start flipping tires from now on, I would usually not do that.
Old May 18, 2018 | 05:48 PM
  #37
tw2's Avatar
tw2
How do you flip/rotate staggered, asymmetric directionals? (Which I hope everyone is running)
Old May 18, 2018 | 06:12 PM
  #38
amgen's Avatar
C55 AMG T with Kleemann K2 and some stuff: 414 hp and 562 Nm :-)
Good question.
Mine always wear on the inside.
When I take off, the car "sits" and the rear wheels wear more on the inside.
At heavy corning, the car is forced to sit flat on the tyres.
I can´t flip mine.
If my rears is wearing to much on the inside, I´m not taking corners fast enough!
Old May 18, 2018 | 10:36 PM
  #39
Pilot SSs can be run in either direction, they only have an inside and outside. No idea of their replacements?
Old May 23, 2018 | 05:28 PM
  #40
SPONSOR
You can flip your tires on any vehicle. Flipping your tires doesn't mean actually taking off the two fronts (or rears) and swapping sides. It means taking it to the tire shop and having them dismount the tires and putting them on the opposite side. I've done this every 10K Miles on my staggered setups for years, and instead of replacing tires every year, I replace them every two to three years. If you flip tires often enough, you'll have a good relationship with the tire shop and they'll probably hook you up if you're nice. I've used the same tire shop for 13 years and sometimes they tell me that it's on the house!
Old May 23, 2018 | 10:21 PM
  #41
tw2's Avatar
tw2
Yes but if your tires are asymmetric as most high performance tires are the inside and outside will be around the wrong way. Yes you can do it. But if you drive your car hard I would not recommend it. The materials, stiffness, and water shedding design is different from inside to outside. The area of maximum grip is also designed to be in a certain spot which you are moving the position of.
Old May 24, 2018 | 03:13 PM
  #42
SPONSOR
Yep, definitely. I personally don't run asymmetric tires because aggressive camber and toe settings will wear out asymmetric tires way too fast. At least with directional tires, I have the opportunity to flip them and double or triple the lifespan of the tire. You're pretty much out of luck if you're trying to get more life out of your asymmetric tires. Overinflating the tire would probably help with wear a bit, but isn't exactly a safe thing to do.
Old Jun 7, 2019 | 06:28 AM
  #43
ruined_c55's Avatar
2005 C55 AMG
Since I've had mine, I've had Pirelli PZeros with stock wheels, Purely fronts/Accelera PHI R rears with my old wheels and now Lionhart LH Fives. Pirellis lasted 12ish K in the rear, Acceleras about 8K, and the Lionharts are too new to give lifespan feedback on. They did surprisingly well up in the canyons in the rain though.
Old Jun 8, 2019 | 02:36 PM
  #44
I'm not brave enough to run cheap Chinese tires on my dirtbike, let alone my daily driver pushing almost 400hp. I get between 15-20k out of much more expensive Michelins but the longer life and tons better grip more than make up for it.
Old Jun 8, 2019 | 03:12 PM
  #45
ruined_c55's Avatar
2005 C55 AMG
I'd say that's a typical response I get. My tire choices are definitely one of the things I get flak for the most. All I can say is I've put nearly 200K across 5 different cars using "Chinese" tires, never had any issues or complaints, and I've installed hundreds of sets going back 7 years now on everything from Civics to Bentleys. Nothing wrong with Michelins though.
