Any custom ideas? HUGE issue from small bolt
I know this is insane--but any ideas of how I or a shop could repair this? I assume something custom will have to be fabricated.
Broken part where lower alternator bolt screws in
Piece that broke off engine block
And I repeat--I didn't "gorilla" it. I've done plenty of work on my cars over the years and have never had an issue like this. I'm always extremely careful. The only idea I have is that the sleeve/spacer in the lower bracket was not seating properly into the bracket. It was going in crooked. That could be what caused the bolt to follow that crooked path.
Would you buy a car from someone with that kind of custom work done?
Id get this part used. There are plenty of salvage yards out there with blown motors that'll part them out. Heck I think I even saw one on the forum here somewhere. Its a M112 part so itll work from any m112 or m113 motor and there are plenty of those.
You can probably get that part used for less than a hundred. I recently the away a m113 block with all that crap on it.
Take it to a good shop and have the timing chain done while at it but honestly you can probably do this kind of job your self.
https://mbworld.org/forums/w211-amg/...ock-awe-2.html
For what it's worth, it is the same on all 112k and 113k engines.
You can try to tig weld that thing back into place but it can be tough to weld a casting like that, especially considering the environment it has lived in.
Things like this are one more reason I enjoy having a machine shop at home.
