Gut check on 17x8 ET37 up front (C55)
So I got set of remanufactured OEM wheels off a w210. They are 17 x 8 all around with an offset of 37.
On the fronts, clearance to the caliper should be about the same as stock, reduced by maybe a millimeter assuming the spokes aren't cast funny.
But the edge of the wheel will ride about 13mm closer to the strut, which is a decent amount. Does anyone with more experience with these cars -- I just got mine -- have an instinct on whether I'll need to get a spacer? Would be nice to know before I drop everything off to the tire shop to get mounted, balanced, and installed.
I sifted through a bunch of threads on aftermarket wheels, but couldn't quite get the info I needed so I thought I'd just ask.
Thanks for your time. The wheels look like this if that helps:
Rears fit fine though a small spacer would help visually.
Front strut clearance is fine. Surprisingly it's the caliper that's an issue. It *just* barely touches right at the top of the spokes because the spokes are curved. 5mm should do it.
