City light bulb removal?
Old Sep 28, 2018 | 08:38 AM
RPB's Avatar
RPB
Hey Guys,
I swapped out my H7 bulbs w/ a set of Phillips this morning. I thought that would take care of the yellow lights than run w/ the xenon, but then I realized those are the high beam bulbs. I’d like to remove the city light beneath the high beams although they’re in there tight.
Is there a specific way to remove these bulbs? I’m not trying to yank on the wires like some do. There seems to be a little tab on the bottom. It does not appear to twist out like the 210/208 series? Such a tight space on these cars!! Any insight would be appreciated!
Cheers,
Rob
Old Sep 28, 2018 | 01:10 PM
RPB's Avatar
RPB
Alright, I had to get a little creative and hope this will help out others down the road. I noticed there was an indent beneath the city bulb housing, it is impossible to get your finger in between to pull out. I found my modified metal hanger I used in the past to pull out clusters and it did the trick. I included a picture of it and all you have to do it take the smaller curved end and insert in that indent a pull out hard. It took me a few tries on both sides. The bulb is in there tight if it has never been removed before!!!
I hope this helps!
