IC Pump?
Old Dec 31, 2018 | 10:37 PM
RPB's Avatar
RPB
IC Pump?
Hey Guys,
I recently acquired an ‘02 C32 w/ 65k miles. My prior car was a 210 E55, I have owned a few examples of this model in the past. The C32 is definitely more agile, but I feel like there is a noticeable lack of power when accelerating. I know the cars vary quite a bit in terms of torque. The car appears to be well cared for its entire life based off the service history. The 2nd owner replaced the oe Valeo radiator w/ Behr and flushed the pertinent fluids around 40k. I’m not finding a record relating to the IC pump, I can only assume the car is running on the original part. I feel the car moves like it should when I kick down at decent speeds (40mph+).
I’m aware this topic has been discussed quite a bit and the original pump is undoubtedly prone to failure. Can someone please provide insight on the obvious signs of pump failure? I plan to check the fuse in the trunk tomorrow, if the fuse is blown is it likely the pump is faulty? What would you guys recommend I inspect next?
Cheers,
-Rob
Old Jan 3, 2019 | 06:01 PM
Morphh's Avatar
C32 amg
u have to check your intake AIR temps to see if pump working it should be around 10-15C above ambient
Old Jan 3, 2019 | 07:42 PM
RPB's Avatar
RPB
I guess there is no simple way to tell if the pump is functioning properly. I’m a bit surprised by this. Some of them last well over 100k and others fail around 40-50k.
I plan on checking the fuse first tomorrow, if not I may leave it till my next svc inspection. Thx
