Mercedes C55 Stuck Crankshaft Position Screw
Old Feb 21, 2019 | 10:54 PM
Lewis Seals's Avatar
2005 Mercedes C55 Amg
Greetings,
Mercedes will crank and will not start again; however, when I look on the torque app I am not getting any {revs} and the check engine light is on with no codes. I was wondering if anyone had a solution to a E8 bolt that was stripped. I replaced this bolt with an aftermarket one and may have been the reason but maybe not. At any rate, I have sprayed it with lube and have used a universal grip tool but did not want to use heat. Any other ideas to get the bolt out without much fuse?
Old Feb 22, 2019 | 03:18 AM
This is the bolt that I used. Actually it states that it is a genuine part?
https://www.ecstuning.com/b-genuine-.../910142006001/
